Hello!
I recently noticed that TeamSpeak 5 is not downloading channel backgrounds, banners and images in channel descriptions.
When the image is hosted on a internet website, it downloads normally. But, when the image is hosted on TeamSpeak’s server (using the program’s file hosting feature), it doesn’t load most of the time.
I don’t think it’s a problem with the server, because in TeamSpeak 3 both banners and channel description images load normally. I just couldn’t test if the channel background images were loading because this version doesn’t have this feature.
Example: TeamSpeak 3 showing the two images from the channel description, in which the first is a GIF (blurred for privacy reasons).
Example: TeamSpeak 5 showing only one (the GIF) of the two images from the channel description.
Analyzing the TeamSpeak 5 logs, I noticed that it gives an error when trying to save the images that don’t load:
I’ve tried clearing TeamSpeak 5’s cache, running it as an administrator, and even reinstalling it again, erasing the leftover folders in AppData. Even so, the problem persists.
I believe it is a bug, since in TeamSpeak 3 the problem does not occur.
Thanks!
