Teamspeak 5 does not show channel icons
Hey everyone,
I just ran into a problem with the TS5 Client on Linux. I set up Channel Icons for every channel on my server using TeamSpeak 3:
However, TS5 does not display them for every channel, only for a few:
Anyone having the same issue and/or an idea for how to fix it?
Thanks
~Jens
We are aware of that problem.
At the moment the only workaround would be to edit the icon file itself save it as a new file or format.
What image formats are supported? All the files I used are .svg files
If you changed icons, clear the cache:
C:\Users\UserName\AppData\Local\TeamSpeak\Cache\Default
After that, it always works for me.
thank you
