I am experiencing a very inconsistent issue with screen sharing in TeamSpeak 6.
When I start sharing my screen, the stream may work normally for some time, but then suddenly drops to 0x0 resolution, 0 FPS, and 0 Kbps upstream. At that point, the stream essentially stops sending any data.
The behavior is extremely inconsistent and I have not been able to identify a reliable pattern. It can sometimes even change when I interact with the TeamSpeak client itself. For example, simply moving the TeamSpeak window to another monitor can sometimes cause the screen stream to stop working.
I have also noticed that the behavior can sometimes vary depending on the number of people in the channel, although I cannot confirm that this is directly related to the issue.
I have already tested different encoders:
NVIDIA NVENC
Intel encoder
Internal Software encoder
The issue occurs with all of them.
I have also tested different bitrate settings, ranging from 640 Kbps up to 10,000 Kbps, and the problem still occurs. Because of this, the bitrate itself does not appear to be the cause.
What makes this more interesting is that other users on the same TeamSpeak server are also experiencing screen-sharing problems, including users who appear to be on different computers and networks. This makes me wonder whether there could be an issue related to the screen-sharing/P2P connection itself, rather than something specific to my system.
I also found this existing thread describing a very similar issue:
In particular, the reports of the stream getting stuck at 0x0 / 0 FPS / 0 Kbps seem very similar to what I am experiencing.
Could this potentially be related to the P2P/NAT/connection handling used by TeamSpeak 6 screen sharing?
Has anyone experienced similar behavior, or is there any logging/debugging information I can provide that would help determine why the screen-sharing stream suddenly stops sending data?
Thank you!
