Teamspeak badges
I cant find out where to enable the badges I currently have so it can be seen when im in a teamspeak server?
You can edit your visible badges in the client settings in the myTeamSpeak tab. There you’ll find a button to edit your badges.
If those are correctly set make sure you have myTeamSpeak features enabled for the server. Either via the bookmark settings or in the new connection window.
