TeamSpeak channel delay delete bug
The Teamspeak 6 client ignores or does not respect channel permissions when it comes to temporary channels and the delete delay.
To reproduce:
Set the global delay in the server to 30 seconds, for example.
Create a test channel and set the channel permission to 5 seconds delay.
Connect to the same channel with ts3 and ts6.
Create a temporary sub-channel with ts3 and leave it again → will be deleted after 5 seconds according to the channel permissions.
If I now repeat this with the ts6 client and create a temporary sub channel and leave it again, the global value of 30 seconds applies!
Thanks for the report.
The channel delete delay permission is not inherited either from the parent channel nor the permissions.
TID:1130
