tried doing it from teamspeak itself but its like the plugin doesn’t exist on there
Yeah ok, but you tried the stable one, right?
correct, and have been in the developers discord as well asking
also tried the testing one as well and no luck. Installed Tokovoip and that works just fine
but the second i installed salty chat it just crashes yet again even with tokovoip installed it just instantly crashes upon launch still
Well I found this in the crashdump:
Unhandled exception at 0x00007FFC902E9709 (KERNELBASE.dll)
in ts3_clientui-win64-1588756070-2020-05-25 10_44_30.862282.dmp:
0xE06D7363: Microsoft C++ Exception
(parameters: 0x0000000019930520, 0x000000ADA5AFCF08,
0x00007FFC5EF631D8, 0x00007FFC5EEF0000).
I can’t find anything else atm. The problem is definitely the plugin itself (I think) so your best shot will be to give the dev(s) access to the crashdump - they will be able to do some more analysis.
sadly the developers couldnt find anything their side and sent us here
Did they take a look at the dmp files?
apparently they did yes
moved by moderator
My Client randomly crashes after a few minutes while in radio with Saltychat - tried all available Saltychat versions, none worked. I have a Crashdump, maybe someone can help me, because I have no Idea what to do with it.
Therefore you need to upload your crashdump here.
Maybe we might be able to help you afterwards.
