skiluc
June 28, 2021, 1:48pm
Hey. I used TS some months ago to play GTA V RP. I desisntalled and installed again for work, but the app crashes when I open the option/settings. I already tried the -safemode. I don’t know what to, because I need this to work.
Dump files: WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
skiluc
June 28, 2021, 1:52pm
In most cases SafeIPs is running and hijacks the client. This does cause a crash.
Make sure you remove or deactivate or whitelist the client.
skiluc
June 28, 2021, 2:39pm
I don’t have SageIPs and tried to disable my firewall, and now are crashing after I open the app. And now i got anot error from log
2021-06-28 14:29:01.661407|INFO | | |TeamSpeak Client 3.5.6 (2020-11-25 13:53:42)
2021-06-28 14:29:01.661407|INFO | | |SystemInformation: Windows 10 (19043) x64 (AMD or Intel) Binary: 64bit
2021-06-28 14:29:01.661407|INFO | | |Using hardware aes
2021-06-28 14:29:01.719419|DEBUG |Direct Sound | |setting timer resolution to 1ms -
2021-06-28 14:29:01.805932|INFO | | |*** Time [SPAWN_EVENTCONVERTER]: 146
2021-06-28 14:29:01.852941|INFO |ClientUI | |OpenGL Info: LibGLES, Vendor: Google Inc., Renderer: ANGLE (NVIDIA GeForce GTX 1060 6GB Direct3D11 vs_5_0 ps_5_0), Version: OpenGL ES 2.0 (ANGLE 2.1.0.57ea533f79a7)
2021-06-28 14:29:01.854441|ERROR |RevocationListCache| |Failed to import revocation list from cache
2021-06-28 14:29:01.959460|INFO | | |successfully downloaded revocation list for accounting
2021-06-28 14:29:02.016970|INFO | | |*** Time [ICONMANGER]: 162
2021-06-28 14:29:02.017969|INFO |Addons | |Checking for addon updates…
2021-06-28 14:29:02.025471|INFO | | |successfully downloaded revocation list for myteamspeak id
2021-06-28 14:29:02.145492|INFO |SyncImpl | |Creating default config in local storage
2021-06-28 14:29:02.216505|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2021-06-28 14:29:02.216505|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2021-06-28 14:29:03.457724|INFO | | |*** Time [BUILD_GUI]: 1235
2021-06-28 14:29:03.485730|INFO | | |*** Time [SERVERVIEW]: 1272
2021-06-28 14:29:03.496231|INFO | | |*** Time [SERVERVIEWMANAGER]: 1293
2021-06-28 14:29:03.662260|INFO | | |*** Time [MAINWINDOW]: 2031
2021-06-28 14:29:03.662260|INFO | | |*** Time [INIT]: 2033
2021-06-28 14:29:03.671261|INFO |ClientUI | |Qt version: 5.12.3
2021-06-28 14:29:03.671261|INFO |ClientUI | |Using configuration location: C:\Users\lucia\AppData\Roaming\TS3Client\settings.db
2021-06-28 14:29:04.973991|INFO |ClientUI | |Last update check was: Never
2021-06-28 14:29:04.979992|INFO |Update | |Checking for updates…
2021-06-28 14:29:04.979992|INFO |Bookmarks | |Collecting autoconnect bookmarks
2021-06-28 14:29:04.980492|INFO |Integrations | |Requesting integration icon download from https://ts3services.teamspeak.com/integration_icons/twitch/twitch.svg
2021-06-28 14:29:04.981492|INFO |Newsticker | |Newsticker language change detected
2021-06-28 14:29:04.981992|INFO |Newsticker | |Newsticker next check:
2021-06-28 14:29:05.047004|INFO |Newsticker | |Newsticker not found for language pt
2021-06-28 14:29:05.058506|INFO |Addon_Download_Manager| |Download completed: C:/Users/lucia/AppData/Local/Temp/control-13win64_5d002c29b8529.ts3_plugin Addon_Uuid:fe337fce-f1c4-425f-a95a-b88d0badda16 Version: 4
2021-06-28 14:29:05.191530|INFO |Addon_Download_Manager| |Download completed: C:/Users/lucia/AppData/Local/Temp/gamepadjoystickpluginwin64_5d0043f73bedc.ts3_plugin Addon_Uuid:9415ef5c-736c-4780-b4df-4cd53c886a8d Version: 8
2021-06-28 14:29:05.269543|INFO |Addon_Download_Manager| |Download completed: C:/Users/lucia/AppData/Local/Temp/clientquerypluginwin64_5d2d9a74826e7.ts3_plugin Addon_Uuid:943dd816-7ef2-48d7-82b8-d60c3b9b10b3 Version: 7
2021-06-28 14:29:05.287047|INFO |Newsticker | |Newsticker received for language pt, expires on ter jun 29 14:29:05 2021 GMT, next check in 86399 seconds
2021-06-28 14:29:05.292048|INFO |Update | |License update available; version 0 to 5 (min version 0 to 4)
2021-06-28 14:29:05.296549|INFO |LicenseViewer | |View license: version=5, language=pt, require accept=1
2021-06-28 14:29:05.297049|INFO |LicenseViewer | |Requesting remote license for version 5 and language pt
2021-06-28 14:29:05.297548|DEBUG |Addon_Install_Manager| |(Package Installer): Add-On successfully installed and activated.
2021-06-28 14:29:05.299549|INFO |Addon_Install_Manager| |Addon installed: Control
2021-06-28 14:29:05.306049|INFO |Addons | |Installing addon Control
2021-06-28 14:29:05.326553|INFO |Plugins | |Loading plugin: teamspeak_control_plugin_win64.dll
2021-06-28 14:29:05.362060|INFO |ControlPlugin | |Control Plugin started, accepting connections
2021-06-28 14:29:05.368060|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/gamepad_joystick/usb.ids
2021-06-28 14:29:05.369561|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/gamepad_joystick/xinput1_4.dll
2021-06-28 14:29:05.371561|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/gamepad_joystick/XInput1_4_win7.dll
2021-06-28 14:29:05.373561|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/gamepad_joystick_win64.dll
2021-06-28 14:29:05.389564|DEBUG |Addon_Install_Manager| |(Package Installer): Add-On successfully installed and activated.
2021-06-28 14:29:05.392565|INFO |LicenseViewer | |Failed to download license file for version 5 and language pt, retrying english fallback
2021-06-28 14:29:05.393065|INFO |LicenseViewer | |Requesting remote license for version 5 and language en
2021-06-28 14:29:05.403068|INFO |Addon_Install_Manager| |Addon installed: Gamepad and Joystick Hotkey Support
2021-06-28 14:29:05.414069|INFO |Addons | |Installing addon Gamepad and Joystick Hotkey Support
2021-06-28 14:29:05.424071|INFO |Plugins | |Loading plugin: gamepad_joystick_win64.dll
2021-06-28 14:29:05.488582|INFO |Gamepad Plugin| |Found client raw input wnd proc
2021-06-28 14:29:05.488582|INFO |Gamepad Plugin| |Cleared device list
2021-06-28 14:29:05.490582|INFO |Gamepad Plugin| |Found device \?\HID#VID_1B1C&PID_1B75&MI_01#8&A88A6B3&0&0000#{4D1E55B2-F16F-11CF-88CB-001111000030}
2021-06-28 14:29:05.533590|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/banadd.txt
2021-06-28 14:29:05.535092|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/banclient.txt
2021-06-28 14:29:05.536091|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/bandel.txt
2021-06-28 14:29:05.537091|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/bandelall.txt
2021-06-28 14:29:05.538591|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/banlist.txt
2021-06-28 14:29:05.539591|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channeladdperm.txt
2021-06-28 14:29:05.540592|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelclientaddperm.txt
2021-06-28 14:29:05.541592|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelclientdelperm.txt
2021-06-28 14:29:05.543092|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelclientlist.txt
2021-06-28 14:29:05.544092|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelclientpermlist.txt
2021-06-28 14:29:05.545092|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelconnectinfo.txt
2021-06-28 14:29:05.546093|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelcreate.txt
2021-06-28 14:29:05.547593|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channeldelete.txt
2021-06-28 14:29:05.548593|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channeldelperm.txt
2021-06-28 14:29:05.549593|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channeledit.txt
2021-06-28 14:29:05.550593|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelgroupadd.txt
2021-06-28 14:29:05.551594|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelgroupaddperm.txt
2021-06-28 14:29:05.553593|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelgroupclientlist.txt
2021-06-28 14:29:05.554094|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelgroupdel.txt
2021-06-28 14:29:05.555093|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelgroupdelperm.txt
2021-06-28 14:29:05.556093|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelgrouplist.txt
2021-06-28 14:29:05.557594|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelgrouppermlist.txt
2021-06-28 14:29:05.558595|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channellist.txt
2021-06-28 14:29:05.560095|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelmove.txt
2021-06-28 14:29:05.561095|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelpermlist.txt
2021-06-28 14:29:05.562095|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/channelvariable.txt
2021-06-28 14:29:05.563095|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientaddperm.txt
2021-06-28 14:29:05.564095|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientdbdelete.txt
2021-06-28 14:29:05.565096|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientdbedit.txt
2021-06-28 14:29:05.566096|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientdblist.txt
2021-06-28 14:29:05.567596|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientdelperm.txt
2021-06-28 14:29:05.568596|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientgetdbidfromuid.txt
2021-06-28 14:29:05.570096|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientgetids.txt
2021-06-28 14:29:05.571097|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientgetnamefromdbid.txt
2021-06-28 14:29:05.571597|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientgetnamefromuid.txt
2021-06-28 14:29:05.573097|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientgetuidfromclid.txt
2021-06-28 14:29:05.574098|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientkick.txt
2021-06-28 14:29:05.575097|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientlist.txt
2021-06-28 14:29:05.576598|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientmove.txt
2021-06-28 14:29:05.577598|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientmute.txt
2021-06-28 14:29:05.578597|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientnotifyregister.txt
2021-06-28 14:29:05.579598|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientnotifyunregister.txt
2021-06-28 14:29:05.581098|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientpermlist.txt
2021-06-28 14:29:05.581599|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientpoke.txt
2021-06-28 14:29:05.583099|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientunmute.txt
2021-06-28 14:29:05.584099|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientupdate.txt
2021-06-28 14:29:05.585099|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/clientvariable.txt
2021-06-28 14:29:05.586100|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/complainadd.txt
2021-06-28 14:29:05.587099|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/complaindel.txt
2021-06-28 14:29:05.588100|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/complaindelall.txt
2021-06-28 14:29:05.589100|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/complainlist.txt
2021-06-28 14:29:05.590100|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/connect.txt
2021-06-28 14:29:05.591600|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/currentschandlerid.txt
2021-06-28 14:29:05.592601|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/disconnect.txt
2021-06-28 14:29:05.593601|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/ftcreatedir.txt
2021-06-28 14:29:05.594600|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/ftdeletefile.txt
2021-06-28 14:29:05.595600|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/ftgetfileinfo.txt
2021-06-28 14:29:05.596601|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/ftgetfilelist.txt
2021-06-28 14:29:05.598101|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/ftinitdownload.txt
2021-06-28 14:29:05.599102|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/ftinitupload.txt
2021-06-28 14:29:05.600102|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/ftlist.txt
2021-06-28 14:29:05.601102|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/ftrenamefile.txt
2021-06-28 14:29:05.602102|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/ftstop.txt
2021-06-28 14:29:05.603102|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/hashpassword.txt
2021-06-28 14:29:05.604102|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/help.txt
2021-06-28 14:29:05.605103|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/messageadd.txt
2021-06-28 14:29:05.606103|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/messagedel.txt
2021-06-28 14:29:05.607103|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/messageget.txt
2021-06-28 14:29:05.608604|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/messagelist.txt
2021-06-28 14:29:05.609603|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/messageupdateflag.txt
2021-06-28 14:29:05.610604|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/permoverview.txt
2021-06-28 14:29:05.612104|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/quit.txt
2021-06-28 14:29:05.613104|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/README.txt
2021-06-28 14:29:05.614104|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/sendtextmessage.txt
2021-06-28 14:29:05.615104|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/serverconnectinfo.txt
2021-06-28 14:29:05.616605|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/serverconnectionhandlerlist.txt
2021-06-28 14:29:05.617605|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servergroupadd.txt
2021-06-28 14:29:05.618605|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servergroupaddclient.txt
2021-06-28 14:29:05.619605|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servergroupaddperm.txt
2021-06-28 14:29:05.620605|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servergroupclientlist.txt
2021-06-28 14:29:05.621606|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servergroupdel.txt
2021-06-28 14:29:05.623106|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servergroupdelclient.txt
2021-06-28 14:29:05.624106|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servergroupdelperm.txt
2021-06-28 14:29:05.625606|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servergrouplist.txt
2021-06-28 14:29:05.627106|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servergrouppermlist.txt
2021-06-28 14:29:05.628107|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servergroupsbyclientid.txt
2021-06-28 14:29:05.629607|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/servervariable.txt
2021-06-28 14:29:05.630607|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/setclientchannelgroup.txt
2021-06-28 14:29:05.631607|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/tokenadd.txt
2021-06-28 14:29:05.632608|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/tokendelete.txt
2021-06-28 14:29:05.633608|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/tokenlist.txt
2021-06-28 14:29:05.635108|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/tokenuse.txt
2021-06-28 14:29:05.635608|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/use.txt
2021-06-28 14:29:05.636608|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/verifychannelpassword.txt
2021-06-28 14:29:05.637609|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/verifyserverpassword.txt
2021-06-28 14:29:05.638609|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin/whoami.txt
2021-06-28 14:29:05.641609|DEBUG |Addon_Install_Manager| |(Package Installer): Writing /plugins/clientquery_plugin_win64.dll
2021-06-28 14:29:05.659612|DEBUG |Addon_Install_Manager| |(Package Installer): Add-On successfully installed and activated.
2021-06-28 14:29:05.701119|INFO |Addon_Install_Manager| |Addon installed: ClientQuery
2021-06-28 14:29:05.710621|INFO |Addons | |Installing addon ClientQuery
2021-06-28 14:29:05.721123|INFO |Plugins | |Loading plugin: clientquery_plugin_win64.dll
2021-06-28 14:29:05.758566|INFO |Query | |listening on 127.0.0.1:25639
2021-06-28 14:29:06.000580|INFO |LicenseViewer | |Downloaded license file for version 5 and language en
2021-06-28 14:29:09.089347|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2021-06-28 14:29:09.089347|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2021-06-28 14:29:09.089847|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2021-06-28 14:29:09.089847|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
