TeamSpeak DNS (same ip but send to different port)
Hello!
I tryed to find this information but seems that i failed. Sorry if there is such information and i have created a new topic about this :slight_smile:
My question is:
If anyone have any ideea if its possible to have 1 IP and 2 teamspeaks with different ports BUT how i can create this DNS to connect on the server without writing the port after DNS .
Example:
ts.teamspeak.com - default port
ts2.teamspeak.com:8888 - and here to connect without writing the port.
"Disclaimer to my answer: I’m not a network pro, so maybe Google’s answer is much better than mine :wink: "
Add ts and ts2 as SRV entry and use 2 different ports. That should be enough to what you want to archive.
When i try to add them as SRV i have to point them “write the target as domain” , any ideea ?
Take a look at this printscreen from DNS Manager zone Screenshot by Lightshot
Enter the target Domain and not an IP. Error is clear there.
Then create a second entry with same Domain as target but with different port.
