Just to give a little bit more details…
The TSDNS
service TeamSpeak uses basically is a similar version of a common DNS service.
Instead of storing ressource records it’s basically storing your TSDNS
name aka. server nickname
and it’s IP address and port.
The system does not require to use FQDN as hostnames in any record since it’s a simplified lookup database.
The primary key or index of this database is the server nickname
you can choose.
That means the server nickname
is an unique value and can’t exist a second time.
By connecting to a server the TeamSpeak app will contact the TSDNS
API to check if the database contains the entered value for the server address
If this lookup will fail it will as next try to resolve the server address
using the global DNS system.
This will fail too, of course if you try to connect using a server nickname
(non-FQDN can’t be resolved)
The whole process of resolving any value you’re using as server address just follows the same sequence over and over again. This can take a while sometimes if any DNS service is slowly at this moment.
Conclusion
Using the IP address to connect to a server is always the fastest way.
