The Teamspeak server is having an extreme high cpu load without a reason. Normally its at 5%!
CPU: AMD EPYC™ 7702
RAM: 8589 MB
Is voice encryption a big point? I disabled it and now the server is running clearly better.
Which TeamSpeak server version did you have?
1.13.3
Okay, I’m still on 3.12.2 myself, but I’ve had the language encryption on every server version so far and it didn’t cause any RAM/CPU problems either
After checking the incoming data I think we we’re part of a DDOS attack… So that’s explaining a lot
Im having the same problem, did you just wait or there is some fix?
