I have been experiencing this issue the past few days and have not had it before but every now and then my microphone gets disabled on TeamSpeak for a reason unknown to me. Can anyone help?
Screenshot: https://i.imgur.com/JdVSeoz.png
The Device seems to be blocked by another application.
Deactivate Give exclusive mode applications priority
in the properties for that device.
And make sure you are using latest client and drivers.
Hello ChrisR,
I have deactivated what you have suggested and will report back after trying to replicate it with some software that may have been causing this issue.
Thanks for your help.
Hello again,
Issue appears to be resolved as a result of deactivating the “Give exclusive mode applications priority” option on the properties of my microphone.
Thanks again ChrisR!
