Hi, TeamSpeak 5 stop loading on logo view. I can not find any logs, so i decided to start app from terminal using this command “/Applications/TeamSpeak.app/Contents/MacOS/TeamSpeak --no-sandbox”.
There are logs from terminal
Please post the full log. Nothing from the part you did show should cause this.
Hi, I found where problem is. Before I can run properly TeamSpeak 5 I must delete files from ~/[user]/Library/Preferences/TeamSpeak/Default/. It looks like files in this directory was corrupted after update. I must delete this files always before I run TeamSpeak.
Logs from client
It looks like this issue has been resolved in update 5.0.0-beta70.
