Do we have any new teamspeak viewer for wordpress?
Thanks in advance
Thanks in advance
There is one plugin, but I don’t think it works.
I can give you advice on how to do it in html / php
You can check my forum to see what it looks like NRG Community Forum | NRG.LU
Yes, should be nice to have some advice how to do it, it will be a wordpress plug-in probably written in php and maybe java as well…
Thanks
So first of all you need to add your teamspeak server on website, ,mine is on this one https://ts3index.com/
When you add your ts, there is a code generator Screenshot by Lightshot then you go to Serverviewer Screenshot by Lightshot and you can designe look. When you are done with designe you just copy the html code and that is it. Screenshot by Lightshot
Hi! There’s a WordPress plugin available at https://ant-f.ru/?page_id=311. Install it on your WordPress server, and you won’t need to rely on third‑party services.
