teamspeak wants to update but will not keep hitting restart several times still on beta 23
also found out under app to remove in win 10 there was 3 different versions of teamspeak 5.0.0 removed all of them
ok managed to remove it all and reinstall to latest but unsire why it showed me 3 different versions of ts
im going to monitor this on the next update and see what it decides to do
i only noticed it as i was trying to remove it
Please uninstall that beta23 and then install beta 24 from beta.teamspeak.com
As mentioned from b24 to next beta your updater problem is fixed.
