TeamSpeak wont launch after hostname change
Hello! I’ve recently changed the hostname on my linux machine. After a reboot I cannot start the TS6 client. Before the reboot it worked just fine. I tried to delete the teamspeak folder from the user .config with no success.
zoltanvagany@main-pc:~/teamspeak-client$ ls
TeamSpeak               hotkey_helper  libolm.so.3                     logo-128.png       soundbackends
chrome-sandbox          html           libtschat_client_lib.so         logo-256.png       teamspeak-client.desktop
chrome_100_percent.pak  icudtl.dat     libtschat_client_lib_export.so  logo-48.png        v8_context_snapshot.bin
chrome_200_percent.pak  libEGL.so      libvulkan.so.1                  patcher
docs                    libGLESv2.so   licenses                        resources.pak
extensions              libcef.so      locales                         snapshot_blob.bin
zoltanvagany@main-pc:~/teamspeak-client$ ./TeamSpeak
[13990:13990:0926/225521.200983:ERROR:process_singleton_posix.cc(358)] The profile appears to be in use by another Chromium process (2052) on another computer (pop-os). Chromium has locked the profile so that it doesn't get corrupted. If you are sure no other processes are using this profile, you can unlock the profile and relaunch Chromium.
[13990:13990:0926/225521.201024:ERROR:message_box_dialog.cc(190)] Unable to show message box: Chromium - The profile appears to be in use by another Chromium process (2052) on another computer (pop-os). Chromium has locked the profile so that it doesn't get corrupted. If you are sure no other processes are using this profile, you can unlock the profile and relaunch Chromium.
[13990:13990:0926/225521.201120:ERROR:main_runner.cc(122)] ContentMainRun failed with exit code 21
libc++abi: terminating
Aborted (core dumped)
Try deleting the Singleton files located here:
rm -rf ~/.cache/TeamSpeak/Default/Singleton*
