Hello, i have a problem with ts3, i start it like always and when the window show up, he close making lagging the mouse cursor for few seconds till he is not closed completely. I will attach the logfile.
2020-11-06 21:21:32.078779|INFO | | |TeamSpeak Client 3.5.5 (2020-11-04 09:57:47)
2020-11-06 21:21:32.078779|INFO | | |SystemInformation: Windows 10 (19041) x64 (AMD or Intel) Binary: 64bit
2020-11-06 21:21:32.078779|INFO | | |Using hardware aes
2020-11-06 21:21:32.203445|DEBUG |Direct Sound | |setting timer resolution to 1ms - **
2020-11-06 21:21:32.282233|INFO | | | Time [SPAWN_EVENTCONVERTER]: 204*
2020-11-06 21:21:32.340079|INFO |ClientUI | |OpenGL Info: LibGL, Vendor: NVIDIA Corporation, Renderer: GeForce GTX 1060 3GB/PCIe/SSE2, Version: 4.6.0 NVIDIA 456.71
2020-11-06 21:21:32.411888|INFO |ZipArchive | |zip open: C:\Users\diana\AppData\Roaming\TS3Client\gfx\Metallic Icon Pack error: -1000
2020-11-06 21:21:32.411888|INFO |ZipArchive | |Failed to load C:/Users/diana/AppData/Roaming/TS3Client/gfx/countries.zip, falling back to C:/Program Files/TeamSpeak 3 Client/gfx/countries.zip
2020-11-06 21:21:32.424855|INFO |Addons | |Checking for addon updates…
2020-11-06 21:21:32.443802|INFO |Plugins | |Loading plugin: radiofx_plugin_win64.dll
2020-11-06 21:21:32.444799|INFO |Plugins | |Api version is not compatible for plugin: C:\Users\diana\AppData\Roaming\TS3Client\plugins\radiofx_plugin_win64.dll
2020-11-06 21:21:32.444799|INFO |Plugins | |Loading plugin: clientquery_plugin_win64.dll
2020-11-06 21:21:32.446794|INFO |Query | |listening on 127.0.0.1:25639
2020-11-06 21:21:32.446794|INFO |Plugins | |Loading plugin: ts3-playclaw6-plugin_win64.dll
2020-11-06 21:21:32.447792|INFO |Plugins | |Api version is not compatible for plugin: C:\Users\diana\AppData\Roaming\TS3Client\plugins\ts3-playclaw6-plugin_win64.dll
2020-11-06 21:21:32.447792|INFO |Plugins | |Loading plugin: SpamBlocker_win64.dll
2020-11-06 21:21:32.450783|INFO |Plugins | |Loading plugin: TS3MassMover_win64.dll
2020-11-06 21:21:32.451781|INFO |Plugins | |Loading plugin: tokovoip_win64.dll
2020-11-06 21:21:32.452778|INFO |TokoVOIP |141|TokoVOIP initialized
2020-11-06 21:21:32.452778|INFO |TokoVOIP |141|Can’t get current channel : invalid server connection handler ID
2020-11-06 21:21:32.452778|INFO |TokoVOIP |141|Error getting all clients from the server : invalid server connection handler ID
2020-11-06 21:21:32.453775|INFO |TokoVOIP |141|Can’t get current channel : invalid server connection handler ID
2020-11-06 21:21:32.453775|INFO |TokoVOIP |141|Error getting all clients from the server : invalid server connection handler ID
2020-11-06 21:21:32.453775|INFO |TokoVOIP |141|Error getting all clients from server : invalid server connection handler ID
2020-11-06 21:21:32.571460|INFO |TokoVOIP |141|Got update json
2020-11-06 21:21:32.571460|INFO |TokoVoip | |init
2020-11-06 21:21:32.573455|INFO |TokoVoip | |No translation available.
2020-11-06 21:21:32.573455|INFO |TokoVoip | |Radio: enabled: true
2020-11-06 21:21:32.573455|INFO |TokoVoip | |init done
2020-11-06 21:21:32.573455|INFO |Plugins | |Loading plugin: teamspeak_control_plugin_win64.dll
2020-11-06 21:21:32.574452|INFO |Plugins | |Loading plugin: NoMove_win64.dll
2020-11-06 21:21:32.574452|INFO |Plugins | |Loading plugin: rp_soundboard_win64.dll
2020-11-06 21:21:32.577445|INFO |Plugins | |Loading plugin: Information_x64.dll
2020-11-06 21:21:32.578442|INFO |Plugins | |Api version is not compatible for plugin: C:\Users\diana\AppData\Roaming\TS3Client\plugins\Information_x64.dll
2020-11-06 21:21:32.578442|INFO |Plugins | |Loading plugin: Mass_Message_Tool_win64.dll
2020-11-06 21:21:32.579440|INFO |Plugins | |Loading plugin: chatlogs_win64.dll
2020-11-06 21:21:32.649283|INFO |Addon | |Addon up to date.
2020-11-06 21:21:32.734057|INFO |Addon | |Addon up to date.
2020-11-06 21:21:32.819827|INFO |Addon | |Addon up to date.
2020-11-06 21:21:32.891667|INFO |Addon | |Addon up to date.
2020-11-06 21:21:32.975449|INFO |Addon | |Not available for this platform.
2020-11-06 21:21:33.044289|INFO |Addon | |Addon up to date.
2020-11-06 21:21:33.124075|INFO |Addon | |Addon up to date.
2020-11-06 21:21:33.192891|INFO |Addon | |Addon up to date.
2020-11-06 21:21:33.263702|INFO |Addon | |Addon up to date.
2020-11-06 21:21:33.349472|INFO |Addon | |Addon up to date.
2020-11-06 21:21:33.387371|INFO |Plugins | |Loading plugin: gamepad_joystick_win64.dll
2020-11-06 21:21:33.388368|INFO |Plugins | |Api version is not compatible for plugin: C:\Users\diana\AppData\Roaming\TS3Client\plugins\gamepad_joystick_win64.dll
2020-11-06 21:21:33.388368|INFO |Plugins | |Loading plugin: BFSGSimCom_plugin_win64.dll
2020-11-06 21:21:33.389366|INFO |Plugins | |Api version is not compatible for plugin: C:\Users\diana\AppData\Roaming\TS3Client\plugins\BFSGSimCom_plugin_win64.dll
2020-11-06 21:21:33.389366|INFO |Plugins | |Loading plugin: notification_plugin_win64.dll
2020-11-06 21:21:33.389366|INFO |Notifications | |Plugin initialized; version 1.0.7 (API 23) built on Jun 18 2019 20:25:41
2020-11-06 21:21:33.390362|INFO |Plugins | |Loading plugin: connectionhistory_win64.dll
2020-11-06 21:21:33.423274|INFO |Addon | |Addon up to date.
2020-11-06 21:21:33.499072|INFO |Addon | |Addon up to date.
2020-11-06 21:21:33.572876|INFO |Addon | |Not available for this platform.
2020-11-06 21:21:33.648672|INFO |Addon | |Addon up to date.
2020-11-06 21:21:33.809243|INFO |Addon | |Addon up to date.
2020-11-06 21:21:33.900000|INFO |Addon | |Addon up to date.
2020-11-06 21:21:33.964827|INFO |Addon | |Addon up to date.
2020-11-06 21:21:34.030650|INFO |Addon | |Addon up to date.
2020-11-06 21:21:34.110436|INFO |Addon | |Addon up to date.
2020-11-06 21:21:34.185237|INFO |Addon | |Addon up to date.
2020-11-06 21:21:34.276022|INFO |Addon | |Addon up to date.
2020-11-06 21:21:34.349824|INFO |Addon | |Addon up to date.
2020-11-06 21:21:53.712006|INFO |Connection History| |PreInit1 - 0, 23, 2, 0, 20292, 0
2020-11-06 21:21:53.712006|INFO |Connection History| |Plugin PreInit: 2 - 20318
2020-11-06 21:21:53.712006|INFO |Connection History| |Plugin Init: 0
2020-11-06 21:21:53.712006|INFO | | |* Time [PLUGINS]: 21269**
2020-11-06 21:21:53.902527|INFO | | |* Time [CONTACTS]: 103**
2020-11-06 21:21:53.916608|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2020-11-06 21:21:53.916608|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2020-11-06 21:21:54.028309|INFO | | |* Time [SERVERVIEW_ACTIONS]: 103**
2020-11-06 21:21:54.029331|INFO | | |* Time [SERVERVIEW]: 115**
2020-11-06 21:21:54.033320|DEBUG |SB | |CurrentServerConnectionChanged: 1
2020-11-06 21:21:54.033320|INFO | | |* Time [SERVERVIEWMANAGER]: 131**
2020-11-06 21:21:54.140034|INFO | | |* Time [MAINWINDOW]: 22067**
2020-11-06 21:21:54.140034|INFO | | |* Time [INIT]: 22068**
2020-11-06 21:21:54.147989|INFO |ClientUI | |Qt version: 5.12.3
2020-11-06 21:21:54.147989|INFO |ClientUI | |Using configuration location: C:\Users\diana\AppData\Roaming\TS3Client\settings.db
2020-11-06 21:21:54.640807|INFO |ClientUI | |Last update check was: ven nov 6 07:47:56 2020
2020-11-06 21:21:54.640807|INFO | | |Statistics report: Not yet, next report on lun nov 23 16:32:28 2020
2020-11-06 21:21:54.641805|INFO |Bookmarks | |Collecting autoconnect bookmarks
2020-11-06 21:21:54.641805|INFO |Bookmarks | | + ☨ADM Survivors☨
2020-11-06 21:21:54.641805|INFO |Bookmarks | | + 7eam’Pandemonium SF2
2020-11-06 21:21:54.642803|INFO |ClientUI |1 |Connect to server: ts3-3.voicehosting.it
2020-11-06 21:21:54.648785|INFO |ClientUI |1 |Trying to resolve ts3-3.voicehosting.it
2020-11-06 21:21:54.695685|INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, “voicehosting.it” =(h: 185.25.204.35 p:0)
2020-11-06 21:21:54.699649|INFO |TSDNS | |A/AAAA DNS resolve successful, “ts3-3.voicehosting.it” =(h: 185.25.204.133 p:0)
2020-11-06 21:21:54.699649|INFO |TSDNS | |SRV DNS resolve unsuccessful, “_ts3._udp.ts3-3.voicehosting.it” Domain name not found
2020-11-06 21:21:54.699649|INFO |TSDNS | |SRV DNS resolve unsuccessful, “_tsdns._tcp.voicehosting.it” DNS server returned answer with no data
2020-11-06 21:21:54.700648|INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, “ts3-3.voicehosting.it” =(h: 185.25.204.133 p:0)
2020-11-06 21:21:55.140787|INFO |Newsticker | |Newsticker next check: sab nov 7 17:46:45 2020 GMT
2020-11-06 21:21:55.160734|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2020-11-06 21:21:55.160734|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2020-11-06 21:21:55.160734|DEBUG |Windows Audio Session| |WAS::openDevice-enter - {0.0.0.00000000}.{c5b267ed-e55b-43d0-a03b-3d51fa8b8ec7}
2020-11-06 21:21:55.164723|DEVELOP |Windows Audio Session| |Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Arctics 7 Game (Arctis 7 Game)
2020-11-06 21:21:55.164723|DEVELOP |Windows Audio Session| |Initializing with mix format. - Arctics 7 Game (Arctis 7 Game)
2020-11-06 21:21:55.198632|INFO |Windows Audio Session| |Initialized with 2 channels in 32bit, 48kHz. - Arctics 7 Game (Arctis 7 Game)
2020-11-06 21:21:55.198632|DEVELOP |Windows Audio Session| |WAS Buffer size: 1056 - Arctics 7 Game (Arctis 7 Game)
2020-11-06 21:21:55.198632|DEBUG |Windows Audio Session| |WAS::openDevice-leave - {0.0.0.00000000}.{c5b267ed-e55b-43d0-a03b-3d51fa8b8ec7}
2020-11-06 21:21:55.198632|DEBUG |Windows Audio Session| |WAS::startDevice-enter - {0.0.0.00000000}.{c5b267ed-e55b-43d0-a03b-3d51fa8b8ec7}
2020-11-06 21:21:55.199630|DEBUG |Windows Audio Session| |WAS::startDevice-leave - {0.0.0.00000000}.{c5b267ed-e55b-43d0-a03b-3d51fa8b8ec7}
2020-11-06 21:21:55.238526|DEBUG |SB | |CurrentServerConnectionChanged: 2
2020-11-06 21:21:55.307368|INFO |ClientUI |2 |Connect to server: pandemonium.voicehosting.it
2020-11-06 21:21:55.307368|INFO |ClientUI |2 |Trying to resolve pandemonium.voicehosting.it
2020-11-06 21:21:55.351250|INFO |TSDNS | |SRV DNS resolve unsuccessful, “_tsdns._tcp.voicehosting.it” DNS server returned answer with no data
2020-11-06 21:21:55.351250|INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, “voicehosting.it” =(h: 185.25.204.35 p:0)
2020-11-06 21:21:55.357234|INFO |TSDNS | |SRV DNS resolve successful, “_ts3._udp.pandemonium.voicehosting.it” =(h: ts3.voicehosting.it p:13067)
2020-11-06 21:21:55.363219|INFO |TSDNS | |A/AAAA DNS resolve unsuccessful, “pandemonium.voicehosting.it” DNS server returned answer with no data
2020-11-06 21:21:55.368205|INFO |TSDNS | |A/AAAA DNS resolve unsuccessful, “pandemonium.voicehosting.it” DNS server returned answer with no data
2020-11-06 21:21:55.405107|INFO |TSDNS | |A/AAAA DNS resolve successful, “ts3.voicehosting.it” =(h: 185.25.204.67 p:0)
2020-11-06 21:21:55.405107|INFO |ClientUI |2 |Lookup finished: ip=185.25.204.67 port=13067 query=pandemonium.voicehosting.it error=0
2020-11-06 21:21:55.405107|INFO |ClientUI |2 |Resolve successful: 185.25.204.67:13067
2020-11-06 21:21:55.405107|INFO |ClientUI |2 |Initiating connection: 185.25.204.67:13067
2020-11-06 21:21:55.435027|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2020-11-06 21:21:55.435027|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2020-11-06 21:21:55.435027|DEBUG |Windows Audio Session| |WAS::openDevice-enter - {0.0.1.00000000}.{da9041fe-3503-4003-b6e5-b81526b0aeb2}
2020-11-06 21:21:55.436024|DEVELOP |Windows Audio Session| |Mix Format: SRate:96000 Bitrate: 32 Channels: 1 - Mic In (2- Elgato Wave:3)
2020-11-06 21:21:55.436024|DEVELOP |Windows Audio Session| |Initializing with mix format. - Mic In (2- Elgato Wave:3)
2020-11-06 21:21:55.455971|INFO |Windows Audio Session| |Initialized with 1 channels in 32bit, 96kHz. - Mic In (2- Elgato Wave:3)
2020-11-06 21:21:55.456969|DEVELOP |Windows Audio Session| |WAS Buffer size: 2112 - Mic In (2- Elgato Wave:3)
2020-11-06 21:21:55.456969|DEBUG |Windows Audio Session| |WAS::openDevice-leave - {0.0.1.00000000}.{da9041fe-3503-4003-b6e5-b81526b0aeb2}
2020-11-06 21:21:55.456969|DEBUG |Windows Audio Session| |WAS::startDevice-enter - {0.0.1.00000000}.{da9041fe-3503-4003-b6e5-b81526b0aeb2}
2020-11-06 21:21:55.460957|DEBUG |Windows Audio Session| |WAS::startDevice-leave - {0.0.1.00000000}.{da9041fe-3503-4003-b6e5-b81526b0aeb2}
2020-11-06 21:21:55.477912|INFO |ClientUI |2 |Connect status: Connecting
2020-11-06 21:21:55.591198|DEVELOP |PktHandler |1 |Puzzle solve time: 3
2020-11-06 21:21:55.781906|INFO |ClientUI |2 |Connect status: Connected
2020-11-06 21:21:55.806869|INFO |TSDNS | |TSDNS queried unsuccessfully 185.25.204.35:41144
2020-11-06 21:21:55.806869|INFO |TSDNS | |No TSDNS found
2020-11-06 21:21:55.819805|INFO |ClientUI |2 |Connect status: Establishing connection
2020-11-06 21:21:55.824793|INFO |TSDNS | |TSDNS queried unsuccessfully 185.25.204.133:41144
2020-11-06 21:21:55.824793|INFO |TSDNS | |No TSDNS found
2020-11-06 21:21:55.896600|INFO |ClientUI |1 |Lookup finished: ip=185.25.204.133 port=13024 query=ts3-3.voicehosting.it error=0
2020-11-06 21:21:55.896600|INFO |ClientUI |1 |Resolve successful: 185.25.204.133:13024
2020-11-06 21:21:55.896600|INFO |ClientUI |1 |Initiating connection: 185.25.204.133:13024
2020-11-06 21:21:55.901586|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2020-11-06 21:21:55.901586|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2020-11-06 21:21:55.917543|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2020-11-06 21:21:55.917543|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2020-11-06 21:21:55.933500|INFO |ClientUI |2 |Connect status: Connection established
2020-11-06 21:21:56.025255|DEVELOP |PktHandler |1 |Puzzle solve time: 6
2020-11-06 21:21:56.468071|INFO |TSDNS | |TSDNS queried unsuccessfully 185.25.204.35:41144
2020-11-06 21:21:56.468071|INFO |TSDNS | |No TSDNS found
2020-11-06 21:21:56.811798|INFO |Plugin |2 |Plugin Mass Message Tool, Version 1.2, Author: Stinger
2020-11-06 21:21:56.931302|INFO |ClientUI |1 |Connect status: Connecting
2020-11-06 21:21:56.952246|DEBUG |SB | |onUpdateClientEvent: serverId = 2, clientId = 176, invokerID = 0, invokerName = “”, invokerUID = ""
2020-11-06 21:21:56.964214|DEBUG |SB | |onUpdateClientEvent: serverId = 2, clientId = 176, invokerID = 0, invokerName = “”, invokerUID = ""
2020-11-06 21:21:56.964214|INFO |ClientUI |1 |Connect status: Connected
2020-11-06 21:21:56.993136|INFO |ClientUI |1 |Connect status: Establishing connection
2020-11-06 21:21:57.000118|INFO |ClientUI |1 |Connect status: Connection established
2020-11-06 21:21:57.555565|INFO |Plugin |1 |Plugin Mass Message Tool, Version 1.2, Author: Stinger
2020-11-06 21:21:57.695192|DEBUG |SB | |onUpdateClientEvent: serverId = 2, clientId = 176, invokerID = 0, invokerName = “”, invokerUID = ""
2020-11-06 21:21:57.784979|DEBUG |SB | |onUpdateClientEvent: serverId = 1, clientId = 1192, invokerID = 0, invokerName = “”, invokerUID = ""
2020-11-06 21:21:57.784979|DEBUG |SB | |Input state of server 1 enabled
2020-11-06 21:21:57.784979|DEBUG |SB | |TSMGR: Setting active server id: 0 -> 1
2020-11-06 21:21:57.784979|INFO |SB | |Server Id: 1ll
2020-11-06 21:21:57.807919|DEBUG |SB | |onUpdateClientEvent: serverId = 1, clientId = 1192, invokerID = 0, invokerName = “”, invokerUID = ""
2020-11-06 21:21:57.828834|INFO |UIHelpers | |setClientVolumeModifier: 1166 0
2020-11-06 21:21:57.829832|INFO |UIHelpers | |setClientVolumeModifier: 1164 6
