I can be sure about that my network is fun, when i join every server for about 15-30 mins, i will lose connection, but my game or other apps which need network is working fun. After i restart TS3 Client, I can connect the server.
I have changed my DNS to 114.114.114.114 8.8.8.8. It’s useless.
I need someone’s help. Hope that can be solved…
Does it happen to you on all servers or only on a specific one?
@opZ1ca
all servers
I add ts3client_win64.exe to pass the Firewall. And now it online about 2 hours and didn’t timeout.
Hope u can give me some advice.
I will test it.
Can you share your log?
|2023/1/16 05:37:17|PktHandler|Info|Cleaning up connection because of 14 resends of COMMAND packet||
|2023/1/16 05:37:17|PktHandler|Info|Dropping client 106 because of resend timeout||
|2023/1/16 05:37:17|ClientUI|Info|Connect status: Disconnected||
|2023/1/16 05:37:17|ClientUI|Info|Connection lost, want autoreconnect = 1||
|2023/1/16 05:37:18|ClientUI|Info|Autoreconnecting||
|2023/1/16 05:37:18|ClientUI|Info|Connect to server: 222.187.227.73||
|2023/1/16 05:37:18|ClientUI|Info|Initiating connection: 222.187.227.73:9987||
|2023/1/16 05:37:18|ClientUI|Info|Connect status: Connecting||
|2023/1/16 05:37:23|ClientUI|Info|Connect status: Disconnected||
|2023/1/16 05:37:23|ClientUI|Info|Initiating connection: 222.187.227.73:9987||
|2023/1/16 05:37:23|ClientUI|Info|Connect status: Connecting||
|2023/1/16 05:37:24|PktHandler|Info|Cleaning up connection because of 5 resends of COMMAND packet||
|2023/1/16 05:37:24|ClientUI|Info|Connect status: Disconnected||
|2023/1/16 05:37:24|ClientUI|Info|Failed to connect to server, want autoreconnect = 1||
|2023/1/16 05:37:25|ClientUI|Info|Autoreconnecting||
|2023/1/16 05:37:25|ClientUI|Info|Connect to server: 222.187.227.73||
|2023/1/16 05:37:25|ClientUI|Info|Initiating connection: 222.187.227.73:9987||
After i reply u I lost the connection xD…
THIS IS THE CMD PING I CAN PING THE IP
Which client are you using?
Teamspeak3 version:3.5.6
Plugins:just have a Chinese translation
I just tested that server and I also lost connection after 7min, this has nothing to do with your internet or client. The problem is with the host. (server host)
It is a chinese server in China. Other friends won’t lost connection. I dont know why. can u send me a server from ur country ? I want to have a test . And my own server also have this problem … 101.43.128.4 u can have a test . thx
OK
If you lose connection to TS5 Client again, then you have a problem with your host.
Let us know
This post was flagged by the community and is temporarily hidden.
