Teamspeak3 is not working. It was working fine before, but after shutting down and restarting my computer one day, the software stopped working. Uninstalling and reinstalling it didn’t work. I can only see the software logo flashing briefly in the taskbar before it closes automatically.
Please show us your logs.
You can find them in: %AppData% -> Roaming -> TS3Client -> logs
2026-02-24 11:53:37.150899|INFO | | |TeamSpeak Client 3.6.2 (2023-09-20 09:48:13)
2026-02-24 11:53:37.151902|INFO | | |SystemInformation: Windows 11 (26100) x64 (AMD or Intel) Binary: 64bit
2026-02-24 11:53:37.176923|DEVELOP |Windows Audio Session| |Hardware agc not available - 麦克风 (ToDesk Virtual Audio)
2026-02-24 11:53:37.178924|DEVELOP |Windows Audio Session| |Hardware agc not available - 耳机式麦克风 (INZONE H5 - Chat)
2026-02-24 11:53:37.178924|DEBUG |SoundDevManager| |Loading dynamic soundbackend from D:/TS3/soundbackends/directsound_win64.dll
2026-02-24 11:53:37.210953|DEBUG |Direct Sound | |setting timer resolution to 1ms -
2026-02-24 11:53:37.273010|DEBUG |SoundDevManager| |Soundbackend loaded.
2026-02-24 11:53:37.274010|INFO | | |\*\*\* Time \[SPAWN_EVENTCONVERTER\]: 123
2026-02-24 11:53:37.319052|INFO |ClientUI | |OpenGL Info: LibGLES, Vendor: Google Inc., Renderer: ANGLE (NVIDIA GeForce RTX 4070 SUPER Direct3D11 vs_5_0 ps_5_0), Version: OpenGL ES 2.0 (ANGLE 2.1.0.57ea533f79a7)
2026-02-24 11:53:37.320053|ERROR |RevocationListCache| |Failed to import revocation list from cache
2026-02-24 11:53:37.399125|INFO |Addons | |Checking for addon updates…
2026-02-24 11:53:37.411135|INFO |Plugins | |Plugins safemode parameter detected, not loading any plugins
2026-02-24 11:53:37.690422|INFO |SyncImpl | |Creating default config in local storage
2026-02-24 11:53:37.716446|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2026-02-24 11:53:37.716446|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2026-02-24 11:53:38.203925|INFO | | |successfully downloaded revocation list for accounting
This is the software’s runtime log. I’ve also tried running it using secure code, but it still didn’t work.
I’ve posted the operation log downstairs, please take a look.
Okay, so you’ve enabled the safemode parameter. Therefore the crash is not due a plugin.
I don’t see anything unusual in your log. The agc hardware is not available, but we’ll put that aside for the moment.
Please check whether a crash dump was created in %AppData%\TS3Client\crashdumps\ and upload it here.
It seems that unsupported file types cannot be uploaded here.
Yeah, you need to upload it via google drive or dropbox or another extern upload.
Afterwards you can share us the link.
I’ve uploaded the file, and you can view it now.thx
I analyzed the crash dump.
The crash is a stack overflow (0xC00000FD) occurring in:
gdi32full!CreateFontIndirectExW
The call stack shows the execution path going through qwindows.dll and Qt5Core.
TeamSpeak uses Qt for its UI, and this pattern is typical for a font creation / font fallback recursion loop during application startup, which means TeamSpeak crashes while trying to create or resolve a font via the Windows GDI layer, and the stack eventually overflows.
Important:
This is not a GPU/DirectX crash. The failure happens inside Windows font handling (GDI), triggered by Qt during UI initialization.
Recommended fix: Reset the Windows Font Cache
Please try the following:
Press Win + R
Type
services.msc -
Stop the service named Windows Font Cache Service
Delete the contents of the following folders (if they exist):
%WinDir%\ServiceProfiles\LocalService\AppData\Local\FontCache\
%LOCALAPPDATA%\FontCache\ -
Reboot the system.
This type of stack overflow in CreateFontIndirectExW is commonly caused by a corrupted Windows font cache.
Please let us know if TeamSpeak starts correctly after performing these steps.
Thx, I’ll give it a try and get back to you later. Thanks for your hard work.
It didn’t work; the situation remains the same as before.
a new crash dump file has been uploaded.
Before we continue with the new crashdump. Please delete your TeamSpeak cache %AppData%\TS3Client\cache and restart the client.
If it still doesn’t work, let’s continue here.
From your new crashdump i can see it’s still a STACK_OVERFLOW (0xC00000FD) during font creation.
The bucket is now gdi32full.dll!InsertCFontCache, but the stack still goes through gdi32full!CreateFontIndirectExW → qwindows.dll → repeated Qt5Core frames, which strongly points to a Qt font fallback / font resolution recursion at startup.
Since resetting the Windows font cache didn’t help, the next likely cause is a problematic installed font or broken font fallback/substitution settings.
As a quick way to find a solution and to be on the safe side, I recommend that you
- try starting TeamSpeak 3 from a fresh Windows user profile (new local user). If it works there, it’s a per-user font/settings issue and
- check recently installed fonts and temporarily remove or disable them (especially any non-Microsoft fonts), then test again.
If you can confirm whether it works under a new Windows user, we can narrow this down quickly.
It seems to be an issue with the new font. After creating a new user locally, TS3 works fine. Thank you so much for your help.
You’re welcome. If you have any further question, feel free to ask! ![]()
