Please change this setting to default channel membership. Enter and exit channel prompts I want to customize the voice file prompts. Which one is more stylized? Where is the default voice prompt in? How can I change it?
Hey there and welcome to the TeamSpeak Forum.
I’m having a hard time understanding what your question or issue is. Could you please explain in more detail? It looks like you’re asking for a certain client setting to be made the default, although I can’t tell from your picture exactly what you mean. The same goes for the “voice prompt” and “voice file prompts” questions.
In case you are using a translator, feel free to type in your native language and we will do our best to translate it and help you with your issues or questions.
Thank you very much!
