The .ts3_plugin is not a recognized file, previous solutions not working
Hi, sorry this question seems to be common, but the solutions from previous discussions are not working.
THE PREVIOUS DISCUSSION RECAP
I’m installing the Task Force Arrowhead Radio mod for Arma 3 and when I try to install Task_force_radio.ts3_plugin, ts3_plugin is not recognized as a file type and Windows prompts me to open it with another application, defaulting to notes. In the discussion from October 23, two users had the same problem. One of them was told to run a .exe file that would allow the file to be recognized. It worked for them, but a second user didn’t see the files in their installation file. However, they reinstalled the Teamspeak client which appeared as “Teamspeak 3” and the files appeared in the folder.
CURRENT PROBLEM
I followed the previous discussion’s suggestions and reinstalled the client, however, it has not changed. The client is not “Teamspeak 3” and the files are still missing from the folder. Does everything have to be installed in the same folder/drive? I don’t know at this point… Any suggestion would be great!
PHOTOS ATTACHED
Screenshot (230)
This won’t work.
You installed the TS5 client and not TS3 where the plugin belongs into.
You need to install the TS3 Client
can i ask how u fixed it im stuck with the same problem idk what to do i have teamspeak 3
You need to open the plugin with the package_inst.exe which is located in the client installation path.
