I installed Tokovoip correctly and if i try to use it on a gta 5 fiveM server it says TokoVoip Offline at the Topleft and i am in the good room in teamspeak but the game just wont recognize TokoVoip anyone has a fix?
to others it work correctly?
api level? ts version?
i think its not ts bug so…
you should write to the addon developer.
if gta/ addon bug we can’t help with it.
