Top Menu disapeared
I use cachyos with Kernel 6.13 and have KDE Plasma 6.2.5 installed. My ts3 version is 3.6.2-2 on my arch like system. My problem is that my top menu just doesnt show anymore. A few days i made a clean OS install and it worked at the start normally. The menu was there. After some days i started today the ts3 client and my top menu doesnt show anymore.
Anyone knowing whats going on? I tried to delete the .ts3client folder in my home directory and also did a re install, but nothing helped.
i have the same problem i just installed arch linux with plasma 6.3.2, when i opened ts3 the first few times i was able to see the top menu but then it randomly disappeared, did you fix this issue?
Same happend to me today, was fine after install. Cachy OS with KDE Plasma, today version.
Something on your system setup is configured so no Qt app renders its own menubar.
Check out these
https://bbs.archlinux.org/viewtopic.php?id=268786
I honestly did not expect an answer. So thank a lot.
The “Global Menu” widget/applet is the problem. Can’t remember adding it, but removing it solved the issue instantly.
