I had posted this originally on the server upgrade thread, but I got a message that this is off topic and has been hidden by the community as not relevant to the that topic so for those of you reading this for the second time, but now as a new topic I apologize.
I had a dedicated TS server (free) running for months without a problem on a Windows 7 64Bit computer dedicated to running just the TS Server. It was used for friends to join while playing the game IL-2 Sturmovik 1946. On January 31st I attempted to join the TS server from my TS Client on my gaming machine and the connection failed. I then checked the server lists and my server was still listed as running. I checked the server computer and discovered the server icon was gone from the system tray/taskbar area. Tried to restart the server, but after a few seconds the icon in the system tray would disappear. Checked the server log and it stated that it could not open a licensekey.dat file and that the server would run, but with limited capability.
I searched the internet and this forum and the consensus appeared to be that my server version needed to be upgraded. I downloaded the latest server version and followed the directions for upgrading exactly as was posted. No matter what I have done the server no longer will run. So now I am at a loss of what to do.
I don’t relish the thought of having to start all over again, adding friends and giving permissions etc.
You gave us a description but this does not help us to know what cold have caused the issue you have.
Please check your server log 0. You may see the error.
Also update your server to the latest one.
Ps. you can ignore the could not open a licensekey.dat thing. You don’t own a license so the server is telling you that he could not find a license file to use and does use the default license instead.
Both? Was under the impressions running multiple servers to avoid paying for a license with more slots than no license setup provides was not allowed in the ToS.
I just had the same thing, private personal server 3.9.1 suddenly just wouldn’t start. Not sure how long its been like that, I haven’t used it for a few weeks.
I downloaded 3.11 and extracted all of the files over the existing ones and its starting again.
Nothing obviously useful to me in the logs.
2020-01-31 20:22:24.100333|INFO |ServerLibPriv | |TeamSpeak 3 Server 3.9.1 (2019-07-02 13:17:23)
2020-01-31 20:22:27.804865|WARNING |Accounting | |Unable to open licensekey.dat, falling back to limited functionality
2020-01-31 20:22:27.804865|CRITICAL|Accounting | |Failed loading default license file!
Screech, how did you manage to jump from it doesn’t work on both of his servers to accusations of licence fraud. Trying it on another box is a perfectly reasonable diagnostic step when something stops working. If he is in the market for a commercial solution that sort of nonsense is going to send him elsewhere.
It is possible I read too much between the lines, but to me when someone says they have a problem “…on both of their servers running 3.9.1…” to me that indicates the have been running two servers and both now fail to run. Had the wording been more like “… my server stopped working and I tested it on my other Linux server and it also failed …” I would not think twice about it. As you can see I started with a question “Both?”, so not really accusing anything, just questioning, and making it clear why I questioned it.
Maybe even write an announcement that the bundled default licenses of old servers have an expiry date and why, now that the issue seems to hit a decent amount of users?
The error message is not exactly straightforward either and from a user’s point of view, it’s just confusing that a bundled license that they usually don’t have to care about becomes “bad” just by time passing.
Your licensing system is in dire need of some usability improvements, at least for non-ATHPs. I don’t know whether ATHPs actually have to deal with the same issues.
I’m paying for a quite useless 32 slots gamer license (I could be using the free license and I guess nobody would even notice) and I have to renew that thing by hand every year and I also forget about that every year which means my server shuts down every year for a brief time until I notice.
It’s 2020. How can I automate this?
You know that your software’s billing system is not up to today’s standards when it’s easier to buy a submarine online than it is to renew your software’s license.
_Mailman, I had the same thing happen to me today. My Server icon was not showing up so I restarted the server and the icon would disappear immediately. I tried updating to the latest version but get the same results. I did a regedit on my registry and deleted all occurrences of Teamspeak, rebooted and reinstalled the server and it still doesn’t work. I tried installing TS on another windows 10 computer but I can’t open the server to configure it.
I have the same problem, I open the server and… instant crash, icon disapear… Tested in 3pcs, one work, but two no… Whit all versions of the ts3server, what is the problem???
atom n270 - w7 32b (main pc, dedicated to teamspeak, 5 or more years, but now dont works)
dualcore 2 t7200 - w7 32b dont work
xeon w3680 - w10 64b - work
xeon w3680 - w7 32b (virtual) - work
tested all whit 3.11.0, 3.10.0, 3.9.1, 3.9.0, etc…
I last successfully started the server (64 BIT version 3.9.1) on January 16th, 2020 and it shut down on 01-31 00:42:30. It had worked fine on January 30th, but when I tried to log into the server on the 31st I could not. I checked the log files which was running 3.9.1 64 BIT:
The computer this server was running on without issue was Windows 7 Home Premium 64 Bit SP1 with a AMD 2100+ 64 bit dual core processor. The TeamSpeak server was the only program running (other than the operating system) on this computer without any issues.
I would have use the code tags, but I have no idea how to do it in this forum. So my apologies for not using them here.
