Ts3 Android 3.4.7/8/9 Crashing
After installing the latest update, the app became unusable, as soon as it connects to a server it crashes instantly
Samsung S25 Ultra
Same problem, it crashes as soon as you try to connect to a server after the last update.
Same problem. I can’t connect to the servers. Maybe a rollback to the old one?
Samsung phone.
Thank you for bringing this to our attention. We are already working on an update to address this issue.
We apologise for any inconvenience caused in the meantime.
We seem to have found two possible workarounds for now:
  1. Go into the settings and make sure that the Recording Frequency is set to 48000
  2. Another workaround could be to use Push-To-Talk in the meantime
Update:
A new version should be available for download.
Update 2:
We’re currently still investigating another crash. Once a new update is ready to go, we’ll let you know.
Both workarounds not working because the client can not connect to the servers. I set it to 48000 but not working.
You need to change the settings before connecting. Those two changes worked on my end, but if you are unsuccessful, then you’ll need to wait until the next update is released.
I change it before i try connect to the servers but nothing. Better I wait to a new update. Thank you. Kind regards.
This workaround worked on my Samsung S25 :+1:
This workarounds working for S25U
We’ve submitting a new Update (3.4.8) to the Play Store. It should not be available to download, please let us know if you are still experiencing any issues.
Just downloaded the update.
Problem solved.
Still can’t connect to the server… android - Xiaomi redmi note 12s
New uptade - problem from yesterday..
What Android Version do you use?
Android 14
