My teamspeak3 client crashed and the source is inside the UI core so it is not fixible in any plugin sourcecode. Stack trace tells the same.
Information:
Teamspeak3 v3.5.7 64bit
Qt Version 5.12.3
crashdump:
Information:
Qt Version 5.12.3
crashdump:
please try start parameter -safemode . This will disable plugins and the client may be usable again. Now you can remove 3rd party plugins and maybe the client won’t crash when you remove the parameter again. I see in your Client Log that you have some plugins, please try parameter.
On Windows make a right-click on the shortcut you usually would use to start the client and then select properties. Then add the parameter as shown.
I think you misunterstood me. My client is still useable i reported a crash inside ts3 core. I don´t need to remove/disable any plugins. It´s a runtime crash which occurs from time to time. But thank you.
Will the dump be checked? As said before it´s a ts3 ui crash. Plugin authors can´t fix this.
Hey @t4styy,
Sorry for the late replay.
I looked at the TeamSpeak Log again and i found this:
2021-08-06 18:40:26.880434|ERROR |Decode | |Stale Decoder detected, terminating it. Was ever active = 1
Stale decoder means, there is a problem between your sound devices and in most cases it happens with usb devices. Please try another playback and capture mode.
If this will not help, try these Steps:
Sorry, that i cant say more, about your problem here.
