TS3 Client does not start - Segmentation Error
Hi Guys, please can I have some help.
I am running Fedora KDE 43, fully up to date.
I have installed via the flatpak and via the .run file from TS official site, I am experiencing the same error for both installations.
Error:
QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
qt.qpa.plugin: Could not load the Qt platform plugin "wayland" in "" even though it was found.
Crashdump ENABLED,  directory is: /home/mango/.ts3client/crashdumps
DUMP defined! Dumpdir is: /home/mango/.ts3client/crashdumps
2026-02-28 15:02:46.298364|INFO    |              |   |TeamSpeak Client 3.6.2 (2023-09-20 09:48:13)
2026-02-28 15:02:46.298455|INFO    |              |   |SystemInformation: Linux 6.18.13-200.fc43.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Feb 19 19:54:01 UTC 2026 x86_64 Binary: 64bit
2026-02-28 15:02:46.305794|DEBUG   |PulseAudio    |   |connected to pulse audio server -
Segmentation fault         (core dumped) ./ts3client_linux_amd64
I have been round the houses for several hours, and I am sure this is something that I have done to my system, but I have no idea how to diagnose this? I have an oldish cpu (AMD Ryzen 7 1800X) and I found some random post that said teamspeak does not always support older CPU’s, how do I find out if this is my issue?
I have also done a gdb thingy, but this did not shed light to my, new to linux, brain.
Starting program: /home/mango/Downloads/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
[New Thread 0x7fffdf3306c0 (LWP 32915)]
[New Thread 0x7fffd39ff6c0 (LWP 32917)]
[New Thread 0x7fffd30cc6c0 (LWP 32918)]
[New Thread 0x7fffd28cb6c0 (LWP 32919)]
[New Thread 0x7fffd20ca6c0 (LWP 32920)]
[New Thread 0x7fffd18c96c0 (LWP 32921)]
[New Thread 0x7fffd10c86c0 (LWP 32922)]
[New Thread 0x7fffd08c76c0 (LWP 32923)]
2026-02-28 15:17:15.140273|INFO    |              |   |TeamSpeak Client 3.6.2 (2023-09-20 09:48:13)
2026-02-28 15:17:15.140351|INFO    |              |   |SystemInformation: Linux 6.18.13-200.fc43.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Feb 19 19:54:01 UTC 2026 x86_64 Binary: 64bit
[New Thread 0x7fffb3fff6c0 (LWP 32924)]
[New Thread 0x7fffb37fe6c0 (LWP 32925)]
[New Thread 0x7fffb2ffd6c0 (LWP 32926)]
[New Thread 0x7fffb27fc6c0 (LWP 32927)]
[New Thread 0x7fffb1ffb6c0 (LWP 32928)]
[New Thread 0x7fffb1efa6c0 (LWP 32929)]
[New Thread 0x7fffb1aca6c0 (LWP 32930)]
[New Thread 0x7fffb12c96c0 (LWP 32931)]
2026-02-28 15:17:15.182807|DEBUG   |PulseAudio    |   |connected to pulse audio server -
Thread 16 "threaded-ml" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffb1aca6c0 (LWP 32930)]
__strlen_avx2 () at ../sysdeps/x86_64/multiarch/strlen-avx2.S:76
I don’t know where or what to do next, is this a bug with TS3?
Thanks for any help :smiley:
I’m having a very similar problem. I believe its due to QT5 not being available anymore, and using QT6. I havent found a working solution yet, but if I do I will post. I doubt it, but hopefully they update it.
