I believe I am on the latest windows version and safemode didnt fix it
Can you try all of these: * Start your client with one of the following parameters:
–force-opengl-desktop
–force-opengl-soft
–force-opengl-angle
Question:
Do you got any plugins installed?
If yes, try removing them - safemode might not have worked.
Also your crashdump said:
2021-04-26 06:09:16.363004|ERROR |SoundBckndIntf| |C:/Program Files/TeamSpeak 3 Client/soundbackends/directsound_win64.dll error: unknown error
So it could be assumed that your windows installation has some problems.
desktop and soft crashed on opening and angle just doesnt open.
Teamspeak used to work just fine so idk why this is happening now
