After Windows update when I try to launch Teamspeak3, I see error 0xc000007b.
I tried all ways to solve this problem but nothing helps.
Before this update TS3 launch without problem.
Please help me.
Have a look at this
Solution 1
In most cases it’s .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from Here
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully.
Solution 3
Re-install Microsoft Visual C++ from [x32 link] or x64
Solution 4
Run Windows Update as it can provide application fixes and updates. Furthermore, it installs missing drivers and updates.
I tried this
Hmm, my guess would have been Step 3 Rikku posted - uninstall + reinstall your VS redistributable, it’s not unheard of for windows update to break them
Thanks. I uninstall all C++ package,reinstall and now run without problems
Nice to hear glad that is now fixed.
Welcome to TeamSpeak.
Have a look at
TeamSpeak - Official TeamSpeak Community Forum
Funny how I found solution to my error in the topic to the another one=)
thanks for the info bro!
