I want to take a backup of my server with ts3 framework to /backups/ folder using post process. how can I do that? can you share the code block?
#!/bin/bash
# Path to your ts3 framework installation
TS3_PATH="/path/to/ts3/framework"
# Path to your backups folder
BACKUPS_PATH="/backups/"
# Stop the ts3 server
"${TS3_PATH}/ts3server_startscript.sh" stop
# Create a timestamp for the backup filename
TIMESTAMP=$(date +%Y%m%d%H%M%S)
# Backup command
"${TS3_PATH}/ts3server_minimal_runscript.sh" backup
# Move the backup file to the backups folder
mv "${TS3_PATH}/ts3server.sqlitedb" "${BACKUPS_PATH}/ts3_backup_${TIMESTAMP}.sqlitedb"
# Start the ts3 server again
"${TS3_PATH}/ts3server_startscript.sh" start
JUST TEST IT OUT BEFORE DOING THIS ON PROD. SYSTEM
I had it running automatically via crontab, ebsp.
“0 3 * * MON” and then the link to the script.
So you have an automatic backup system for your data
(data without rifles)
my codes are working on hosting i have not established ssh connection i am coding with php pdo. I want to take a backup by clicking the form button.
i dont know what you mean, or want to do…?
I’m building a web panel, I want to take a backup of the server with the button there.
yes easy, then take the code from above, make a script out of it, and execute the script on your server via button. done?
I guess I need to provide ssh2 connection there. I am using teamspeak3 framework and I manage it through hosting panel. I’m not connecting to the server via ssh2.
for backup use this software: https://yat.qa/
