On my laptop, after reinstalling Windows, starting TC3 has become a real problem: as soon as I start, the friezes begin, turn off TC3 - they stop.
I tried both the 32 and 64 bit versions, and watched the kernel load in the task manager, and checked with an antivirus, and changed local disks, and downloaded from the official site, and started from the admin, and checked other “talkers”, for example, Discord - with they are all ok. Can you help me?
Hey buddy,
Firstly can you post your specifications?
Crashlog?
do you checked if you are meeting actually the Minimal Requirements?
TeamSpeak 3 Client
Windows
Windows 7 SP1, 8.1, 10 and above, 32- and 64-bit
CPU
SSE2 capable CPU
Memory
The TeamSpeak Client requires around 20-60 MB RAM, depending on the number and size of the currently connected servers.
Minimum 1 GB RAM recommended. Some operating systems may require more RAM to run properly.
Harddisk
60-100 MB free (depending on operating system)
