Why aren’t icons appearing on the mobile client?
I have the same Problem
@binpower93 @TS.ChrisR This is a Bug?
I have exactly the same problem! And I have to confess, is really annoying!
Cheers
gotta be a bug, same thing happening for me
Thanks for this, can you provide more details so we can look into this:
Device
Operating System version
App Version
Were you using Mobile (3g/4g/5g), WiFi or other
(@Shoone_4ndr01d I see that you’ve reported similar so if you provide more details as above that would be great)
huawei p smart 2019
android
teamspeak 3 latest andorid version
wifi
when i log in to a server on teamspeak I dont see the icons showing its just a empty space were there should be the icon
@binpower93 can you please reply
Operating System: Android 10
Ts3 Version: Latest Version
Device: Xiaomi Mi A2
Connection: Wifi
Samsung Galaxy S9+
Android 10 (OneUI 2)
3.3.4 (happen on the last beta too since I am inside the beta program)
4G/4G+ and Wi-Fi.
Anyway, I enjoy this message to ask: Is there any planned update to add the possibility to connect to more than one TeamSpeak Server like is possible on iOS?
Cheers
Thanks guys, we’ll have a look into this.
Not on TS3
Just to update that issue. We can reproduce it and will fix it ASAP.
well I tried so hard but no success
