Hi, I have a TeamSpeak 3 Server (Latest Version) and TeamSpeak3 Client (Latest Version)
I am getting these error more often today. (Screenshot Below)
What are those about and how to fix them?
Also, Where can I know the status of the myteamspeak connectivity (server status)?
Thanks
Rikku
June 29, 2020, 2:00pm
Do you have any problem with the myTeamSpeak Services?
It is sending me myteamspeak services error again and again. It was working fine for last 2-3 months and I have been using myteamspeak for like 2 years already.
I don’t know why is it sending this error today. I have tried re-starting too.
The services seem to be fine.
Can you ping/reach clientapi.myteamspeak.com or myteamspeak.com at all?
Else he would not have the Warnings
Yes, I am able to ping them for sure. I have attached the screenshot below.
But, when I directly go to the clientapi.myteamspeak.com it throws Google’s 404 Error.
myteamspeak.com
Edit: Again sent me the error right after replying.
And you pinged clientapi.myteamspeak.com
Only see myteamspeak.com
It’s intended that you get a 404. This page only shows content for the client.
Yessir, I did ping.
ping to clientapi.myteamspeak.com
@TS.ChrisR I have renamed the thread to make it more relative.
Hi, I am still looking for the answer. Errors are still coming.
I have non that will solve the issue.
The service is working fine so far and we did not get any other report the last days.
Maybe a firewall or Antivirus is causing this or from time to time you get high ping or packet loss?
Maybe your ISP started to block some packets?
Okay, How can I check if it’s because of Antivirus or ISP?
