TS3 Silent Installation
Hi All,
I am trying to install TS3 Client silently. I need help on below queries.
1.Silent Installation Parameters
What are the command-line parameters that can be used with the installer, along with /S for silent installation? In the UI mode, we have options to select the configuration file location and choose whether to install Overwolf. How can these options be handled silently?
2.Auto-Update Behavior
Does the application auto-update? If so, is there a silent switch or parameter to disable auto-updates? Additionally, where is user data stored (e.g., file path or registry)?
3.License Activation
Is it possible to activate the license key silently during or after installation via the command line? Will the license key be unique per user or machine, or is it the same across all users/machines within a network or single-tenant setup?
  1. /S for silent installation
    /D=c:\installationpath
    /Overwolf should work to install the client with Overwolf
  2. The TS3 client does not automatically update, if a new update will be released in the future it would prompt the user that a new update is available but does not automatically update itself.
    → Installation path: C:\Program Files\TeamSpeak 3 Client
    → User data path: %appdata%\TS3Client
  3. The client itself does not have a license system. For every commercially used TS server the company you are providing the service to will need to purchase the according license by reaching out to our BizDev Team at [email protected]
Hi Marcel,
Thank you for the information. Is there a way to suppress or disable the update notification prompt in the TeamSpeak 3 client?
Not that I know of. The prompt will only be sent out when an update is released and once dismissed will never show up again.
Since TS3 no longer receives feature updates, any update released would most likely be security related and should then be installed as soon as possible.
