Hey guys,
does any of you have some Docs for a TS3 Style/Theme?
Or does anyone know if it is possible to change the texts / order of variables in the client/channel overview? (Related to my last Question)
Thank you for any answer
Hey guys,
You can edit the files âclientinfo.tplâ and âchannelinfo.tplâ inside âstyle/yourthemeâ.
For example if you have a theme named âYourTheme.qssâ inside the folder âstyleâ you need to create a folder inside âstyleâ with the name of you theme âstyle/YourThemeâ and inisde this folder you can put the files âclientinfo.tplâ and âchannelinfo.tplâ â âstyle/YourTheme/clientinfo.tplâ.
So you should have this hierarchy:
âstyle/YourTheme.qssâ
âstyle/YourTheme/channelinfo.tplâ
This is a list of variables you can use inside your clientinfo tpl file:
And this for the channel tpl:
(Note: All variables must begin and end with %%, example: %%CLIENT_NAME%%)
Correct me if I made some mistakes.
I know that iâm able to edit the right part.
I try to edit the left part. Do you know if this is possible?
Names in server tree cannot be changed.
We decided against this during development of TS3.
Okay, thatâs an explanation.
Will there be the option in TS5? Or is there any good reason that it wonât.
And what about the ability to change the color of the speak-status circle? Or some string in the line after the Nickname.
Maby in combination with my other question about the plugin development? (Topic)
This can be made by editing Icon Pack. You can even change circles into triangles if you really wish. You can use .pngs and .svgs for that.
And this, AFAIR, is impossible, but I havenât had a deep dive look at it for a looong time now.
hi, how i can print the CLIENT IP on client info ??, on documentation say CONNECTION_CLIENT_IP is were the IP is but i canât print the IP adress, any way to do it ??
NOTE: I have server owner permission for see client ip
You donât do that. As you may did read there is no such variable.
The IP is only visible in the connection info or server log.
