I’m looking to send TTS over a TS3SDK client server setup written in C#.
Firstly which is the best forum to ask this question on the new system?
Secondly does anybody know if this can be done without creating a virtual audio device?
I’ve been scouring the web for a few weeks now.
So if I go down the custom capture and wav file route…
Do I create a custom device and Aquire the data from the wav?
Would that then play over the network (ie instead of a mic input)?
Is there a certain format the wav file needs to be?
Any help appreciated.
