Since beta start i cant login into ts5 (i can use it and have my badges)
and i cant go online Imgur picture and i have to enter my recover code often.
And this is the reason why…
When you entered the code or skipped that part and start with a new encryption then you can login.
But when you leave your account in that state then you won’t be able.
and how can i fix that?
This should be it.
