can i get a ts5 beta code?
No you need to register on beta.teamspeak.com to get access
If you have not registered to join the beta at any point β You can sign up to join the closed beta on beta.teamspeak.com . Please note you will need a myTS account to receive access to the beta. You can sign up for a myTS account here: https://www.myteamspeak.com/ so you are able to receive access to the closed beta.
How can I check if I have access to the closed beta or not?
You can either:
- Check this on myteamspeak.com and review your badges after you login.
- If youβre on TS3: Tools β Options β myTeamSpeak β Configure Badges β This should show you every badge that you have.
- You can also login to beta.teamspeak.com itself, login and if you are taken to the downloader screen, then you have been given closed beta access.
