So, I have this weird bug as soon I launch ts5 client, it appears in the taskbar for a second then crashes.
I’ve tried restarting and uninstalling. Attaching the logs and crash dump links.
The log folder is strange. This seems to happen since a while for you. You got many empty logs and then logs where it works again and then where it doesn’t again etc.
Have you tried to rename the settings.db and start with a fresh one?
what happens when you rename the cache folder (or delete it)
This alos may help
I will send the crashdump to our devs.
Hi, I just tried all these things (launch option, deleting cache folder, deleting settings file), Unfortunately, none of these worked. It used to happen a few times earlier but it always worked on the second launch so I didn’t bother about it. Now it just refuses to launch.
Same here…
[21:26:05.862] [info] TSBindingBrowserTSChat ctor
[21:26:05.862] [info] TSChat library version: 1
[0527/212605.668:INFO:crash_reporting.cc(219)] Crash reporting enabled for process: browser
[0527/212605.731:INFO:crash_reporting.cc(219)] Crash reporting enabled for process: gpu-process
[0527/212606.093:INFO:crash_reporting.cc(219)] Crash reporting enabled for process: utility
[0527/212606.106:INFO:crash_reporting.cc(219)] Crash reporting enabled for process: utility
[0527/212606.111:INFO:crash_reporting.cc(219)] Crash reporting enabled for process: renderer
[0527/212606.112:INFO:crash_reporting.cc(219)] Crash reporting enabled for process: renderer
Can you please upload a crashdump? You can find the crashdump under:
%LOCALAPPDATA%\TeamSpeak\User Data\Crashpad\reports
Yeah
Link1: Upload Files Easily | Fast File Upload and Sharing Up To 10GB
Link2: Upload Files Easily | Fast File Upload and Sharing Up To 10GB
downloaded beta 54.1 from the website and the issue seems to be fixed , ts5 in running again
Where i can download beta 54.1 cuz i cant change the to a spec. version?
There it downloads 5.0.0 for me all the time.
That’s the point of that website.
There is only one version of the installer online.
Online is TS Beta version 54.1.
