@opZ1ca
i didn’t understand much
Read carefully from beginning to end…
still didnt understand
If you dont understand this, than translate it to your Language. Or what do you mean?
So birthday cake will be welcomed
Will i still be able to get the badge on my day-to-day account if i use a temp account for the test?
Yes. But it is already explained in the first post.
Can someone explain the part of "Homebase move " ?
I can’t find a right-clickable server where there is this option.
Thanks.
You will be able to set your Homebase on Wednesday.
You can’t see the option yet because the setting is disabled on the server. Once it is enabled (on Wednesday), you will be able to set your Homebase there.
Yeah i understand @opZ1ca explained it to me
in ts dm’s
It’s wednesday and I still can’t find the option to set my Homebase. Am I missing something or isn’t it enabled yet?
Also what exactly do you mean by “Set up Chat”, do we have to configure something particularly?
Check the timestamp.2 hours 56 minutes from now.
It is currently disabled.
If I may ask, how long does a test like this take?
I think round about 30 Minutes
Thank You
r
