TS5 Updates always stuck on "Validating Teamspeak"
For me, every time when Teamspeak 5 gets an update I have to reinstall the client to update because its always stuck on “Validating Teamspeak”. And if I try to restart the client, it just doesn’t open at all. Is there anything that I can do to fix this?
Reads like some software is blocking the process or the next.patch file.
You have any ts5client…log and update.log for us?
Path for these is
%localappdata%\TeamSpeak\Logs\Default
Is there anything in Windows Events?
[2021-04-29 18:37:24.066] [default] [info] patching result: 0
[2021-04-29 18:37:24.085] [default] [info] patching result: 0
that’s the content in update.log, not sure if it’s relevant
[2021-04-30 16:22:08.709] [info] Notifications_Windows ctor
[2021-04-30 16:22:08.931] [info] TeamSpeak Client 5.0.0-beta51 (2021-04-29 07:39:39)
[2021-04-30 16:22:08.931] [info] SystemInformation: Windows 10 (19042) x64 (AMD or Intel) Binary: 64bit
[2021-04-30 16:22:08.932] [info] Using hardware aes
[2021-04-30 16:22:09.414] [info] disconnected from push system.
[2021-04-30 16:22:10.568] [info] connected to push system.
[2021-04-30 16:22:18.586] [info] Initialized with 2 channels in 32bit, 48kHz. - Speakers (Realtek High Definition Audio)
[2021-04-30 16:22:38.766] [info] starting download for http://update.teamspeak.com/windows/x64/latest/info.json
[2021-04-30 16:22:48.825] [info] Notifications_Windows dtor
and this is the content in ts5client_2021-04-30_16-22.log
I guess that is a AntiVirus or another Program blocking the Process. :frowning:
The client log is not helping. Must be one where update was downloaded.
Update log also shows nothing wrong so far.
