TS6 Server Help
Hello all,
I have recently swapped back to teamspeak and have no experience with the new updated application as opposed to teamspeak 3. I am hosting a small 6 slot server for a group of friends and im currently struggling to understand how to customize the server at all, and cant seem to find anything online to really help me as I am honestly not even sure what to look up for it as it is so new. We like the idea of being able to use Teamspeak 6 for the screensharing feature as opposed to teamspeak 3, unless there are addons we are unaware of that allow that there.
TLDR: Im looking for anyone that is willing to help me with running a server on teamspeak 6 as a whole.
If you right click the Server name at the top of the Server Tree you can go directly to the specific Server setting.
The Server settings itself have not changed that much, as the Server can still be used with the TS3 Client. So it might be easier to configure it with TS3 depending on your preferences.
@LeonMarcelHD I didn’t read it wrong, did I? There is a new client, but is it easier to make settings from the old client? What exactly are TeamSpeak developers doing right now?
I’m just saying depending on your preferences.
If I understood correctly that the OP used to be a TS3 user and may be more familiar with the UI.
When I started using the new client 5 years ago. I preferred the old familiar UI from TS3. Time now has passed and I’m confused whenever I open the old client.
I believe there are more important issues that TeamSpeak developers/officials/employees need to answer.
