Hi!
Could someone explain to me step by step how to do it when I have Ubuntu 22.04 with a database and phpmyadmin. What do I need to do first to start the installation
You have everything explained on their website step by step.
Ye, but I moved the folder on my vps to the http folder so I could access the install file through the browser and after configuration the bot didn’t want to connect so I’m probably doing something wrong
You have a log where you can see the errors.
YOUR.domain/ranksystem/webinterface/bot.php
Do I have to install these PHP extensions separately or are they installed with the PHP installation?
You have to set the appropriate PHP version in the installation.
