UI reload crashes connection view
As I stated here already:
When using Ctrl + R all current servers are kinda lost…
You are still connected but…
It worked just fine in previous versions.
Any idea why this is happening @TS.ChrisR ?
There is no support to reload the UI so anything can happen here if you try to.
Soooo it is possible but not supported?
Yes. Please do not report this as a bug. Devs need it for programming.
Maybe in final this gets completely disabled.
Ok I see…
I still don’t like thew idea of having a functionality implemented that is not meant to be used!
(Although I really liked this “feature” when it worked)
Maybe you could do somthing like this:
#if DEBUG
			if (input == (CTRL_KEY + R_KEY) )
				reload();
#endif
So it is still usable for debug purposes but not part of the release build.
Just an idea though.
