Unable to Connect to any Servers
When trying to connect on any servers. Stuck on loading spinner indefinitely.
Intel Mac. Previous beta worked fine. TeamSpeak 3 client on same computer and on IOS able to connect to servers fine. Other computers (Linux, Windows) able to connect to servers on TeamSpeak 6 client.
Thankssssss
Same problem (ARM Mac). Updated the client mid-conversation and now I can’t connect to any server, the connection gets stuck on the loadng spinner and never resolving. Complete reinstall didn’t help.
Hey, could you provide a few more details? :slightly_smiling_face:
  • Which macOS version are you using?
  • Does the issue occur only with server nicknames, or also with IP addresses and domain names?
  • Have you only tried connecting through bookmarks, or have you also tried other methods, such as Quick Connect via the search bar?
Please also send me your CEF and client logs. You can find the relevant folders here:
Config: ~/Library/Preferences/TeamSpeak/Default
Logs: ~/Library/Logs/TeamSpeak/Default
Cache: ~/Library/Caches/TeamSpeak/Default
Sorry for late reply, had a lot on my plate that day and couldn’t take the time to properly write a reply. The issue resolved by itself sometime after you’d replied, I had taken no apparent action that might have fixed it. Here’s what I can provide to the best of my ability. The issue still persists regularly and goes by its own:
OS: MacOS 15.7.2
TeamSpeak client: 6.0.0-beta5
Behavior: Trying to connect to my self-hosted TeamSpeak LAN server via Bookmarks, Quick Connect, and directly over IP results in indefinite loading spinner, eventually timing out in a minute or two with the following error message: “Failed to establish connection to TeamSpeak server! Reason: failed connection initialization”. The side-panel on the left is accessible and working.
Another connectivity issue
One other (similar?) issue I have had happen is TeamSpeak spontaneously, though somewhat rarely, losing connection with the “coordinator” server (see the screenshot below, the entire left sidebar is in perpetual loading, with Servers, Chats, Bookmarks, Contacts, etc completely inaccessible) which I’ve had occur once over the last few days, eventually resolving by itself without any intervention. The other party (they use Windows client) who I talk with on the server regularly also reported sometimes experiencing the same issue.
I also must note that, even without any issues occurring, sometimes the time it takes to “enter”/connect to the server varies noticeably, ranging from instanteniously to 4-6 seconds (even though it’s on a local network and I’m not sure if connectivity to TeamSpeak servers may influence the time it takes to connect to a local TeamSpeak server. The client is perfectly functional all the time outside of the mentioned spontaneously occuring issues.
Relevant log file screenshots:
ts5client_2026-10-21_21-10.log (with error in question on the right)
cef.log
tschat.log (look for the lines starting from 21:10, that's the most recent time I've had the issue occur again)
If there’s any other specific log file I can provide, then please let me know.
  • MacOS Sequoia 15.6.1. Updated to Sequoia 15.8.2 and the problem persists.
  • When I try doing quick connect, nothing comes up. So I cannot attempt to connect with IP addresses.
  • Yes. I tried deleting the bookmarks to re-add them, but they do not delete.
  • It’s telling me new users cannot upload attachements.
Since Quick Connect isn’t responding and you’re unable to delete existing bookmarks, I’m starting to suspect a client-side issue rather than a simple network connectivity problem.
There have been similar Quick Connect issues in previous TeamSpeak 6 beta versions, so I wouldn’t rule out a regression in Beta 5.
Could you clarify what happens when you click Quick Connect? Does the dialog fail to open entirely, or does nothing happen after entering a server address?
I’d also be interested to know whether the same issue occurs when running TeamSpeak from a fresh macOS user account. That would help me determine whether it’s related to your existing client profile or the application itself.
Seems like it. Connectivity is flawless on iOS 26.1 and Windows 11. I pinged every single IP that TeamSpeak is usually connecting to (chat-1.tmspk.net, myteamspeak.com, etc) and they all ping fine and it shouldn’t be a DNS issue or anything.
When typing the IP, in the Quick Connect field, a drop-down bar saying “Resolving…” is shown briefly upon each keystroke. When finished typing the IP, the drop-down bar is saying “No results” instead of “Quick Connect” with the IP in question. Screenshots:
macOS client (faulty behavior):
Windows 11 client (expeced behavior):
Both screenshots were taken simultaneously while trying to connect to the same server, IP blurred for privacy reasons. Trying to connect via the WAN IP instead of the local one is also unsuccessful.
Just tested. Unfortunately, the issue persists even on a fresh user account.
P.S.: The client would occasionally have spurs of connecting just right via both Bookmarks and Quick Connect with resolving the IP just right, but it’s a rare occasion and there’s no telling what’s causing it.
That’s actually pretty strange, especially since it still happens on a fresh macOS user account and occasionally works without any obvious reason.
I’m starting to wonder if this might be something specific to the macOS version of TeamSpeak rather than your network.
Have you tried connecting to a completely different TeamSpeak server to see if the same thing happens?
I’m also curious what happens if you press Enter or click the arrow when Quick Connect shows “No results”. Does it still try to connect, or does nothing happen?
Maybe it’s also worth taking a look at the client logs after a failed attempt. There might be something useful in there.
My guess is it’s either the macOS version of TeamSpeak or just the specific macOS version. Me and the other user who reported the same issue both run macOS Sequoia, which is two versions behind the latest one.
Yep, same thing when trying to connect to servers on the Popular Servers menu (eu-east-1, TS-community, etc) and servers from the Discover Communities menu. Infinite loading spinner (that sometimes times out with an error).
Nothing happens when both clicking the arrow and pressing Enter when it shows “No results”. But if I have the server IP/hostname bookmarked, it would actually recognize it, like on the screenshot with my local server.
When trying to connect that way (pressing Enter/clicking the arrow), I am redirected to the same infinite loading spinner page. When the server isn’t in Bookmarks, nothing happens at all, and nothing is autosuggested (the “No results” scenario).
I have previously shared a few log files here (under the spoilers) that I screenshotted right after a failed attempt. I kind of had to manually look around in the folders, so if there’s specific log files that I didn’t provide, I could try looking for it with a file name.
Is this just an AI bot? You’re just repeating the same things over and over again. It’s obviously a TeamSpeak 6 client problem. The client logs were provided after the initial post.
Can an actual Dev look at this problem? @TS_Dennis
I’m just a normal community member trying to help out here.
I know I repeated a few questions, but I was just trying to figure out what was causing the issue. Some of the tests, like trying a fresh macOS account and checking how Quick Connect behaves, actually helped narrow things down.
I also missed that the logs had already been posted, so that’s my mistake.
Still, I don’t think it’s fair to call someone a bot just because they’re trying to help.
Anyway, considering everything that’s already been tested, I think this is something the TeamSpeak team needs to look into.
Exactly the same for me, also on Sequoia 15.6.1
Update: the client can no longer connect at all despite numerous attempts (it could spontaneously connect before) for about 3 days. If client’s connectivity depends on the TeamSpeak coordinator servers and some changes have been made recently on the backend, they might be the cause.
We’ll see if we can reproduce the issue internally. Sorry for all the AI-generated replies (We all love AI until it starts writing every reply on the forum.)
Can you guys sent me your logs via pm ? Or add me in TS6 and sent it there, so we can talk directly and try to figure out what the problem is
P.S. Have you already checked the client’s privacy settings in your system preferences?
I was able to reproduce this issue while a microphone permission prompt from TS3 was still open. I couldn’t connect to a server until I granted TS3 microphone access. However, I assume this is an entirely separate issue.
I have the same problem.
These are my system environment and logs.
macOS Sequoia 15.7.4 @Apple M3 Max 128GB
Temspeak 6.0.0-beta5 / Build Number:1791901251
Build Date:10/13/2026, 10:20:51 PM / Chromium Version:151.0.7922.76
TeamSpeak Server 3.13.7 Linux
When I access a LAN server via a bookmark, the entire TS6 interface just keeps showing a spinning loading icon.
Additionally, the build number and Chromium version on the About page will disappear.
The build date will become the time at which the connection to the server is established.
Within the same network environment, a computer running TeamSpeak 3 is able to connect successfully.
Sometimes the Mac client connects successfully, but I haven’t figured out why yet.
As a newly registered user, I am unable to upload attachments directly; I have pasted the log below.
cef.log
[19705:354156:1103/203833.223099:WARNING:../../../libce9f38f08e8b4c0/s/src/chromium/src/chrome/browser/signin/account_consistency_mode_manager.cc:74] Desktop Identity Consistency cannot be enabled as no OAuth client ID and client secret have been configured.
ts5client.log
[2026-11-03 20:38:13.942] [info] [SettingsDatabase] journal_mode=wal
[2026-11-03 20:38:13.948] [info] Notifications_Mac ctor
[2026-11-03 20:38:13.950] [info] TeamSpeak Client 6.0.0-beta5 (2026-10-13 14:20:51)
[2026-11-03 20:38:13.950] [info] SystemInformation: Darwin 24.6.0 Darwin Kernel Version 24.6.0: Mon Jan 19 22:02:06 PST 2026; root:xnu-11417.140.69.708.3~1/RELEASE_ARM64_T6031 arm64 Binary: 64bit arm64
[2026-11-03 20:38:14.136] [info] [HK-PORTAL] initHotkeys active_profile=aa7fad2c-26b8-52f6-e79c-8a3216b42069 user_initiated=false
[2026-11-03 20:38:14.614] [info] set_role_volume: role=Notification linear=0.0749894 native=0 mixer=0
[2026-11-03 20:38:14.880] [warning] sync_event, account status change: 2
[2026-11-03 20:38:14.984] [info] Hot Reload!
[2026-11-03 20:38:15.131] [info] set_role_volume: role=Notification linear=0.0749894 native=0 mixer=0
[2026-11-03 20:38:15.164] [info] No speakers assigned to channels. Please do this in AUDIO MIDI SETUP of osx. Defaulting to stereo for now
[2026-11-03 20:38:15.164] [info] Opened playback device with 2 channels at 192000 Hz -
[2026-11-03 20:38:15.260] [info] successfully downloaded revocation list for myteamspeak id
[2026-11-03 20:38:15.398] [info] successfully downloaded revocation list for accounting
[2026-11-03 20:38:15.733] [info] set device for AudioBridge.
[2026-11-03 20:38:15.734] [info] set_role_volume: role=Notification linear=0.0749894 native=0 mixer=0
[2026-11-03 20:38:29.323] [info] launching TeamSpeakUpdater: /Applications/TeamSpeak.app/Contents/MacOS/TeamSpeakUpdater /Applications/TeamSpeak.app 19676 /var/folders/f_/s7ptnrm97pg58xjgwhk6f4740000gn/T/f78e-1125-c4e6-1189
[2026-11-03 20:38:29.357] [info] [shutdown] BeginShutdown trigger=UserRequested (first)
[2026-11-03 20:38:29.359] [info] [shutdown] preparation binding_message_thread took 0ms
[2026-11-03 20:38:29.359] [info] [shutdown] preparation chat_command_runner took 0ms
[2026-11-03 20:38:29.359] [info] [shutdown] P1 start
[2026-11-03 20:38:29.359] [info] [shutdown] P1 flush_pending_settings_transaction took 0ms
[2026-11-03 20:38:29.359] [info] [shutdown] P1 export_clientlib_cache took 0ms
[2026-11-03 20:38:29.372] [info] [shutdown] P1 persist_myteamspeak_state took 12ms
[2026-11-03 20:38:29.375] [info] [shutdown] P1 save_all_presence_and_data took 2ms
[2026-11-03 20:38:29.375] [info] [shutdown] P1 ws_save_settings took 0ms
[2026-11-03 20:38:29.375] [info] [shutdown] P1 flush_and_checkpoint_final took 0ms
[2026-11-03 20:38:29.375] [info] [shutdown] P1 complete in 16ms
[2026-11-03 20:38:29.375] [info] [shutdown] P2 start
[2026-11-03 20:38:29.431] [info] [shutdown] P2 ws_abort took 0ms (inline)
[2026-11-03 20:38:29.431] [info] [shutdown] P2 decentral_filetransfers_shutdown took 0ms (inline)
[2026-11-03 20:38:29.431] [info] [shutdown] P2 http_client_finalize took 0ms (inline)
[2026-11-03 20:38:29.431] [info] [shutdown] P2 complete
[2026-11-03 20:38:29.431] [info] [shutdown] P3 CloseAllWindows(force=true)
[2026-11-03 20:38:29.431] [info] [shutdown] P3 close barrier already complete; quitting CEF loop
[2026-11-03 20:38:29.432] [info] [shutdown] P4 start (MainContext::Shutdown)
[2026-11-03 20:38:29.481] [info] Notifications_Mac dtor
[2026-11-03 20:38:29.507] [info] [shutdown] CefShutdown took 25ms
[2026-11-03 20:38:33.242] [info] [SettingsDatabase] journal_mode=wal
[2026-11-03 20:38:33.247] [info] Notifications_Mac ctor
[2026-11-03 20:38:33.248] [info] TeamSpeak Client 6.0.0-beta5 (2026-10-13 14:20:51)
[2026-11-03 20:38:33.249] [info] SystemInformation: Darwin 24.6.0 Darwin Kernel Version 24.6.0: Mon Jan 19 22:02:06 PST 2026; root:xnu-11417.140.69.708.3~1/RELEASE_ARM64_T6031 arm64 Binary: 64bit arm64
[2026-11-03 20:38:33.437] [info] [HK-PORTAL] initHotkeys active_profile=aa7fad2c-26b8-52f6-e79c-8a3216b42069 user_initiated=false
[2026-11-03 20:38:33.936] [info] set_role_volume: role=Notification linear=0.0749894 native=0 mixer=0
[2026-11-03 20:38:34.162] [warning] sync_event, account status change: 2
[2026-11-03 20:38:34.270] [info] Hot Reload!
[2026-11-03 20:38:34.418] [info] set_role_volume: role=Notification linear=0.0749894 native=0 mixer=0
[2026-11-03 20:38:34.449] [info] No speakers assigned to channels. Please do this in AUDIO MIDI SETUP of osx. Defaulting to stereo for now
[2026-11-03 20:38:34.449] [info] Opened playback device with 2 channels at 192000 Hz -
[2026-11-03 20:38:35.014] [info] set device for AudioBridge.
[2026-11-03 20:38:35.015] [info] [HK-PORTAL] initHotkeys active_profile=aa7fad2c-26b8-52f6-e79c-8a3216b42069 user_initiated=true
[2026-11-03 20:38:35.015] [info] set_role_volume: role=Notification linear=0.0749894 native=0 mixer=0
[2026-11-03 20:39:03.248] [info] starting download for http://update.teamspeak.com/mac/armv8/atomic/latest/info.json
[2026-11-03 20:39:03.889] [info] connected to push system.
[2026-11-03 20:40:47.910] [info] Opened capture device with 2 channels at 192000 Hz -
[2026-11-03 20:40:47.912] [info] Connecting to 10.0.90.5:9987
[2026-11-03 20:40:47.912] [info] Connecting to resolved address 10.0.90.5:9987
