Hello there.
I had recently reformatted, installed, and started-up TS5 beta… I didn’t realize I had my unique ID saved to I recovered or whatever…
I was trying to find out how to input my ID… Thought maybe I could export… change the ID in the ini and re-upload it, but the beta does not have export.
I also tried uninstalling and deleting everywhere I found that TS was installed and it was STILL using the newer id even after all of that.
Soooo… is this a beta thing? should I delete the beta and go to something else??? Help would be appreciated.
