Using Sinusbot on Community
Hello Teamspeak Team
I’ve rented a TS6 server from you and wanted to ask if Sinusbot works with it? In the settings, I can select the port under Advanced Remote Apps. Everything has been entered for Sinusbot, including the desired port, but unfortunately it doesn’t seem to work. Is there a way to use Sinusbot on a TS6 server? If so, how does it work?
I have a question about the permissions system. I would like to create a co-admin and copy the server admin and save it as a co-admin. Then configure the desired settings. Unfortunately, copying the server admin isn’t possible. The only options are renaming and deleting. What’s the situation here? Is there a way to do this?
Thanks
Regards
Hoschy
Depending on the client version of the Sinusbot, he is not allowed to join TS6 servers. If the client version is not 3.6.0 then it will not work. If the bot is not up to date, you can manually update the version but I am not sure how to do that, as the bot is not developed or maintained by us.
Permission copying is currently only possible in TS3. We’ll have that on the list for future TS6 updates.
