Hi, I’ve been having an Issue with Teamspeak 3 where when trying to start the app, I get the following error:
The code execution cannot proceed because VCRUNTIME140_1.dll was not found Reinstalling the program may fix this problem.
I’ve tried reinstalling Teamspeak 3 - Same issue. I even manually redownloaded the VCRUNTIME140_1 dll file, no fix. If someone has a way to fix this, I’d appreciate it.
That file should be part of the visual c++ redistributable distribution.
I’d try to install the latest vcredist package in hopes it contains the 140_1 runtime you’re missing.
See if that fixes your issue :).
Are you using 64bit or 32bit TS3?
That file would be in C:\Windows\System32 for 64bit installation and C:\Windows\SysWOW64 for 32bit.
Try reinstalling the vcredist package, it might be that those files are corrupt.
You can also run a system integrity check if you think that might help.
If you did reinstall/repair the vc++ runtime and it is not working still I’d wait for the teamspeak dudes to respond for further instrucitons.
Would not recommend downloading core OS DLLs from any other site than a genuine Microsoft one.
Eepecially Russian/Indian sites.
Such DLLs might contain malicious code inside them and this might break your computer. I would rather suggest googling a phrase like ”vcruntime140 not found” or anything like that. Maybe there is a solution to that and if not, then it might be necessary to do a OS reinstall.
Once more, DO NOT DOWNLOAD CORE OS FILES FROM ANY OTHER SITE THAN OFFICIAL ONES, UNLESS YOU KNOW WHAT YOU’RE DOING AND/OR THIS IS YOUR LAST RESORT! THIS MIGHT BREAK YOUR COMPUTER IF YOU’RE NOT CAREFUL ENOUGH!
