Very bad sound with Kinect microphone array
Since the version 3.5 of Teamspeak, the voice captured is slow and choppy if the microphone used is the microphone array of the Kinect v2 from Microsoft.
I tested with the latest beta of TeamSpeak 5, it’s the same.
With the 3.3.2 version, no problem. With another microphone, no problem too.
I think the Kinect from Microsoft is not supposed to be used as a Microphone on a Computer. The Problem I think is that this Device is officially supposed to work with an Xbox.
Kinect 2 for Windows is design to work on a computer. All others software works fine, only recent Teamspeak version have this problem.
I use it for Windows Hello and for video meetings (with Microsoft Teams by example) and it’s a really good device for that.
I have the same problem with my new professional laptop : HP EliteBook 855 G7.
I’m using the integrated microphone.
Could it be that you have a too low upload bandwith available? you can check the bandwith within the channel settings. (don’t exceed 90% of your max bandwith) ?
Did you tried your Microphone in the Windows settings under
→ Sounds → Capture → Microphone → Listen → Use this device to listen?
or Playback options, untick the auto gain?
