Voice activity detection doesn’t work in hybrid or automatic mode
Hi there,
Voice activity detection doesn’t work in hybrid or automatic mode. In volume gate mode or push-to-talk it works fine. This behavior occurs both on ts3 and ts6
Arch linux - Wayland - Pipewire
ts6.0.0-beta2
ts3.6.2
UA Volt 276
Does it not work at all or just sometimes not?
Does the blue talking indicator never activated when using the hybrid or automatic?
How the modes are working:
When using automatic or hybrid as a VAD mode, background noises will not trigger a microphone input.
In automatic mode the client will detect speech and it will enable the microphone and others can hear you.
In hybrid mode it will enable your microphone if you are above the set volume and the client detects speech.
Doesn’t work at all and the blue talking indicator doesn’t light up, as if the microphone was turned off.
I’ll forward this to QA to have a look at the issue.
I found the problem. It didn’t work because of the “pro audio” profile in pipewire. I changed profile to Analog Stereo, reinstalled TeamSpeak and everything worked. I noticed when starting teamspeak with pro audio profile, I get the notification “error”
