Voice Quality Drops when watching a Screenshare
Hi, i have a TS6 Community Server and i noticed that the Voice Quality of everyone is droping for me, if i watch a video stream of someone.
The moment i close the stream, the voice quality gets back to normal. Whats makes it strange, sometimes its completly fine and i can watch a Video-Stream and have no Voice Quality Drop. I try to figure out if it is a certain Day or Time, but for now, i cant tell.
My connection to the server is good, ping is something around 20ms and i have no package loss or something. and nothing of that is changing when i watch a Video-Steam.
Others on my Community noticed the same.
Is there something i can do about that?
TID: 2177
What codec / quality settings is set on your channel?
Opus Voice 7.71KiB/s
Does this happen when streaming without audio?
Can you capture an example of this behaviour?
Do you know when this first started to appearing?
it was like that since i have the server.
Yes it happens only when someone is streaming with audio. if i close the stream, the audio gets back to normal. when someone is streaming without audio, the voice quality does not drop.
I will try to make a record of the problem the next days. but it sounds like the mics of all others start to overdrive all of a sudden when the stream turned on
